    Send a file from one Lopy to another Lopy
    lopy to lopywlanwifi lopy
    27 Posts 2 Posters 8.4k Views 2 Watching
    • Z Offline
      zceld
      Hi, nice to see you again.
      I'm trying to send a .txt file from one lopy to another via WIFI and I do not know how to do it.
      I have been testing with 'socket.socket' but it gives me an error and I am not so sure that it is the correct method. It is also that the Lopy where the file will be received can not be left listening while waiting because it is executing another code.
      issuer code:
      from network import WLAN
      import sys
      def buscarWifi(ssid):
          #Ponemos el wifi en modo estacion:
          wlan = WLAN(mode=WLAN.STA)
          #Buscamos wifi:
          redes = wlan.scan()
          print('Redes disponibles: ',len(redes))
          #for c in range(len(redes)):
              #print(c,'->',redes[c])
              #if ssid in redes[c]: //Otra opción de encontrar el ssid
              #print("Encontrado en:",redes[c])
              #return True
          for red in redes:
              if red.ssid == ssid:
                  wlan.connect(red.ssid, auth=(red.sec,'witeklab@2018'), timeout=5000)
                  while not wlan.isconnected():
                  return True,wlan
                  break
                  return False,wlan
      ok,w = buscarWifi('Gateway1')
      if ok:
          print('ok')
          ip = w.ifconfig()
          print('ip destino = ',ip[0])
          print(w.ifconfig())
          #Creamos el fichero:
          #f = open ('prueba.txt', 'w')#MOdo 'a' Para añadir no sobre escribir
          #texto = ip[0]+"\nPrueba1"
          #f.write(texto)
          #f.close()
          HOST = 'localhost'
          PORT = 9876
          ADDR = (ip[0],PORT)
          BUFSIZE = 4096
          videofile = "prueba.txt"
          bytes = open(videofile).read()
          print (len(bytes))
          client = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
          client.connect(ADDR) ## <-- Failure
          client.send(bytes)
          client.close()
          #s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
          #s.connect((ip[0],9999))
          #l = f.read()
          #s.send(l)
          #s.close()
          #Intentamos el envío del fichero:
          #s = socket.socket()
          print('no')
      #Pag de interes:
      # + info : https://docs.pycom.io/chapter/firmwareapi/micropython/usocket.html
      # http://help.ubidots.com/connect-your-devices/connect-your-pycom-devices-over-wi-fi
      The code what it does is look for a wifi network in particular that is what generates the Lopy server and connects correctly and I want to send a .txt file generated in the Lopy and send via Wi-Fi to the connected Lopy.
      Is there a better way to do it?
      By the way I have already looked at the following documents documents:
      https://docs.pycom.io/chapter/tutorials/all/wlan.html
      https://docs.pycom.io/chapter/firmwareapi/pycom/network/wlan.html
      https://docs.pycom.io/chapter/firmwareapi/pycom/network/server.html
      And I have not managed to figure out how to make it sorry.
      • sebS Offline
        seb
        Just look up any standard python example of sending files and this will most likely port directly over to micropython. The basic idea is that you open the file you want to send, read it line by line and then send it line by line. On the other end you just need to read and write to a file.
        Looking at the code you have posted above I have two comments:
        1. Make the socket blocking before sending data because you might be closing the socket before the data has actually been sent if you do it non-blocking.
        2. I would recommend sending the file line by line instead of reading the whole file into the bytes variabile. You might find with large files you will run out of RAM because of this.
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          zceld @seb
          @seb said in Send a file from one Lopy to another Lopy:
          But ... if the destination Lopy is executing an infinite loop carrying out some processes, is it possible to send it over wifi without having to listen, or anything like FTP?
          • sebS Offline
            seb @zceld
            @zceld
            Look into the "select" library or using threads if you want to do things concurrently
            • Z Offline
              zceld @seb
              @seb
              I have searched a lot and I have not come across any example that will finally help me to know how to send a file by socket.
              I know it's a lot to ask but ...Please, do you think it would be possible for you to write me two examples of how to send it and how to receive it from lopy to lopy with micro python using socket?
              I know it's a lot to ask but ... Do you think it would be possible for you to write me two examples of how to send it and how to receive it from lopy to lopy with micro python using socket?
              thank you very much!
              • Z Offline
                zceld
                Up, some good Samaritan who gives me a hand with the code ...
                Is that there is no sure way that if it surpasses what I am doing in each moment I would get to get it out, better or worse but I would take it out. But there is no way ...
                If I do this on the server:
                def iniciarFTP():
                    try:
                        import network
                        wlan = network.WLAN(mode=network.WLAN.STA)
                        wlan.init(mode=WLAN.AP, ssid='Gateway1', auth=(WLAN.WPA2,'witeklab@2018'), channel=7, antenna=WLAN.INT_ANT)
                        from network import Server
                        server = Server(login=('micro', 'python'), timeout=600)
                        server.timeout(300)
                        server.timeout()
                        print(server.isrunning())
                        return True
                    except:
                        return False
                iniciarFTP()
                and in the client I connect like this:
                nets = wlan.scan()
                for net in nets:
                    print (net.ssid)
                    if net.ssid == 'Gateway1':
                        print('Network found!')
                        wlan.connect(net.ssid, auth=(net.sec, 'witeklab@2018'), timeout=5000)
                        wlan.ifconfig()
                        break
                I just need the socket type code to send a file.txt but for more than try it gives me error with the name of the server or a thousand other things ...
                I can not get it out, if someone is bored a moment and can write the code of the client and server to send and receive via wifi would be very grateful because now I just want to send them to that space. XD
                please please :(
                • Z Offline
                  zceld
                  Well nothing for more that I try things I can not send anything. I keep writing to see if anyone can help me.
                  This is the code that runs the server Lopy. About this code I do not know if there will be problems because as I can not connect, I do not know if something fails. But create the wifi network in which the client connects correctly as you can see in the client capture:
                  def iniciarFTP():
                      try:
                          import network
                          server.timeout(300)
                          server.timeout()
                          return True
                      except:
                          return False
                  #Iniciamos servidor:
                  iniciarFTP()
                  #Ponemos a la escucha:
                  f = open('recieved.txt', 'w')
                  eggs = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
                  eggs.bind(('', 8206))
                  eggs.listen(5)
                      channel, details = eggs.accept()
                      print ('connected')
                      got = channel.recv(4096)
                      f.write(got)
                      channel.send("recieved!")
                      channel.close()
                  This is the code of the Lopy client in which I get an error on line 47.
                  What I do is look for the Wi-Fi network that the Lopy server generates and connect me as a client. So far so good. The next thing I try is with the ip obtained from the connection I assign to the variable 'HOST' the ip of the Lopy server and the PORT because it is listening. But when doing 's.connect (ADDR)' gives error:
                  complete code of the client Lopy:
                  import sys
                      #Buscamos wifi:
                      redes = wlan.scan()
                      for red in redes:
                              return True,wlan
                              break
                              return False,wlan
                  if ok:
                      print('ok')
                      ip = w.ifconfig()
                      print(w.ifconfig())
                      print(w.isconnected())
                      HOST = ip[0]
                      PORT = 8206
                      ADDR = (HOST,PORT)
                      BUFSIZE = 4096
                      s.connect(ADDR)
                      f = open("prueba.txt")
                      linea = f.readline()
                      while linea != "":
                          print(linea)
                          s.send(linea)
                      f.close()
                      s.close()
                      print('Connection failed!')
                  I have tried many more ways to do it but almost all of them gave me another type of errors. For example I also found an adaptation of the python FTP library for micro Python but it did not work either ... At last and the caba I just want to do the same thing that Filezilla does when you connect to the Wi-Fi of a Lopy that is sending you a file .. .
                  If someone can help me? thanks in advance, regards.
                  • Z Offline
                    zceld
                    It seems that finally they are between lopys and connect because the server prints this:
                    Now the client seems to give me another error but this one I do not know what it means:
                    OSError: (Errno 113) EHOSTUNREACH
                    • sebS Offline
                      seb @zceld
                      @zceld
                      error host unreachable - this means the lopy could not find a route to the destination
                      • Z Offline
                        zceld @seb
                        If you do not find it as it is on the print server ('connected') when I run the client code? What am I missing?
                        • sebS Offline
                          seb
                          can you post your complete code and I will have a look
                          • Z Offline
                            zceld @seb
                            Thank you very much for looking at it. This is the full code of the Lopy Server:
                            import socket                   # Import socket module
                            def iniciarFTP():
                                try:
                                    import network
                                    server.timeout(300)
                                    server.timeout()
                                    return True
                                except:
                                    return False
                            iniciarFTP()
                            host = ''
                            port = 8206                     # Reserve a port for your service.
                            s = socket.socket()             # Create a socket object
                            s.bind((host, port))            # Bind to the port
                            s.listen(5)                     # Now wait for client connection.
                            print ('Server listening....')
                                conn, addr = s.accept()     # Establish connection with client.
                                print ('Got connection from', addr)
                                data = conn.recv(1024)
                                print('Server received', repr(data))
                                with open('received_file.txt', 'wb') as f:
                                    print ('file opened')
                                        print('receiving data...')
                                        data = s.recv(1024)
                                        print('data=%s', (data))
                                        if not data:
                                            break
                                        # write data to a file
                                        f.write(data)
                                    f.close()
                                    print('Successfully get the file')
                                    s.close()
                                    print('connection closed')
                                    conn.send('Thank you for connecting')
                                conn.close()
                            No more, now I give you a screenshot of what you do when you run it, but I already told you that it stops when you print ('Server listening ....')
                            As the programming indicates waiting for some connection. But the one that receives a connection from the client fails with the error 'OSError: 128':
                            Now we go to the client Lopy code:
                            import sys
                                redes = wlan.scan()
                                for red in redes:
                                        return True,wlan
                                        break
                                        return False,wlan
                            if ok:
                                print('ok')
                                s = socket.socket()
                                ip = w.ifconfig()
                                print('Configuracion de red:',w.ifconfig())
                                print('Estoy conectado=',w.isconnected())
                                ip = w.ifconfig()
                                host = ip[2]
                                #print(type(HOST),'--->>',HOST)
                                port = 8206
                                s.connect((host, port))
                                s.send("Hello server!")
                                filename='prueba.txt'
                                f = open(filename,'rb')
                                l = f.read(1024)
                                while (l):
                                   conn.send(l)
                                   print('Sent ',repr(l))
                                   l = f.read(1024)
                                f.close()
                                s.close()
                            and the error that appears to me in this case is:
                            I do not know what that error means, nor do I know if I'm doing things right. The only thing I know is that at least now they connect to Lopy client and Lopy server, which is already a lot, having to study how the socket system works.
                            That's why in some comment I said, I was requesting some exemplary code of how the system should connect between a client and server and transfer a file.
                            I have taken the code example from here:
                            http://www.bogotobogo.com/python/python_network_programming_server_client_file_transfer.php
                            Although I would like to be able to use the last one with Thread but I have not known how to adapt it to mircro python:
                            http://www.bogotobogo.com/python/python_network_programming_server_client_file_transfer.php#ec2
                            • sebS Offline
                              seb
                              @zceld said in Send a file from one Lopy to another Lopy:
                              import sys
                              redes = wlan.scan()
                              for red in redes:
                              return True,wlan
                              break
                              return False,wlan
                              if ok:
                              print('ok')
                              s = socket.socket()
                              ip = w.ifconfig()
                              ip = w.ifconfig()
                              host = ip[2]
                              port = 8206
                              l = f.read(1024)
                              while (l):
                              conn.send(l)
                              l = f.read(1024)
                              f.close()
                              s.close()
                              Looking at your second block of code it looks like you are trying to connect the device to itself? You are getting host from ifconfig() but then trying to connect to that address
                              • Z Offline
                                zceld @seb
                                host = ip[2]
                                Hi, thanks again for checking it out!
                                In theory the server returns these values of WLAN.ifconfig ():
                                Of the data that ifconfig returns are:?
                                ('ip assigned', 'subnet mask', 'ip server'?, 'and this last one I do not know' /0.0.0.0).
                                Capture of the client, this time trying to connect to the ip '192.168.4.1' that is supposed to be the server's Wi-Fi therefore the Lopy server does not?
                                • sebS Offline
                                  seb @zceld
                                  @zceld
                                  The return of ifconfig is in the following format.
                                  (ip, subnet, gateway, dns)
                                  I see now from your code that you are using one of the modules as a wifi AP, can you first try connecting them to an existing network to see if this works, then we can narrow down if the issue lies with the networking or your logic
                                  Z 2 Replies Last reply Reply Quote 0
                                  • Z Offline
                                    zceld @seb
                                    @zceld
                                    Now I will try to reduce where the problem may be, but the need to connect and send data is to be used without a router, if you do not communicate with each other.
                                    Regardless of the Wi-Fi, do you think that you could send two messages simultaneously with LoRa using thread?
                                    • Z Offline
                                      zceld @seb
                                      @seb
                                      This is the result that the server connected to Wi-Fi has given me, and to which it has begun to receive data from the client, it has failed:
                                      code used in the superior test:
                                          #Buscamos wifi:
                                          redes = wlan.scan()
                                          for red in redes:
                                                  wlan.connect(red.ssid, auth=(red.sec,'hszh6539'), timeout=5000)
                                                  return True,wlan
                                                  break
                                                  return False,wlan
                                      iniciarFTP()
                                      ok,w = buscarWifi('S9+ Wifi')
                                      if ok:
                                          print('ok')
                                          ip = w.ifconfig()
                                          host = ip[0]
                                          print('my ip = ',ip[0])
                                          port = 60000                     # Reserve a port for your service.
                                          gc.collect()
                                              data = conn.recv(256)
                                                      s.setblocking(True)
                                                      print('Memoria->',str(gc.mem_free()))
                                                      data = s.recv(256)
                                                      print('M despues->',str(gc.mem_free()))
                                                      if not data:
                                                          break
                                                      f.write(data)
                                                  f.close()
                                                  s.close()
                                              conn.close()
                                              gc.collect()
                                      Result of the Lopy that sends the file:
                                      import sys
                                          #Buscamos wifi:
                                          redes = wlan.scan()
                                              #return True
                                          for red in redes:
                                                  return True,wlan
                                                  break
                                                  return False,wlan
                                      if ok:
                                          print('ok')
                                          s = socket.socket()
                                          print('ip destino = 192.168.43.26')
                                          #host = ip[]
                                          port = 60000
                                          s.connect(('192.168.43.26', port))
                                          l = f.read(256)
                                          while (l):
                                             conn.send(l)
                                             l = f.read(256)
                                          f.close()
                                          s.close()
                                      • sebS Offline
                                        seb
                                        Please excuse the delay. I have gone ahead and written some code for you to demonstrate sending a file between devices. Be aware that this does no error checking/retries etc. but the basic functionality is there.
                                        Client
                                        import select
                                        # Connect to server AP
                                        nets = wlan.scan()
                                        for net in nets:
                                                wlan.connect(net.ssid, auth=(net.sec, 'password'), timeout=5000)
                                                break
                                            raise Exception("WiFi network not found")
                                        # sleep just to make sure the wifi is connected
                                        ip, subnet, gateway, dns = wlan.ifconfig()
                                        # Connect to server
                                        port = 12345
                                        s = socket.socket()
                                        print("Connecting to: ", gateway, port)
                                        s.connect((gateway, port))
                                        s.setblocking(True)
                                        s.settimeout(2)
                                        file = "/flash/test.txt"
                                        with open(file, 'wb') as f:
                                                try:
                                                    data = s.recv(1024)
                                                    print(data)
                                                    f.write(data)
                                                except TimeoutError:
                                                    break
                                        Server
                                        import select
                                        #Setup WiFi AP
                                        wlan = WLAN(mode=WLAN.AP,
                                                    ssid='Gateway1',
                                                    auth=(WLAN.WPA2,'password'),
                                        # Bind to the port
                                        port = 12345
                                        s = socket.socket()
                                        s.bind(socket.getaddrinfo("0.0.0.0", port)[0][4])
                                        s.listen(1)
                                        print("Running server")
                                            readable, writable, errored = select.select([s], [], [])
                                            for s in readable:
                                                cl, remote_addr = s.accept()
                                                cl.setblocking(True)
                                                print("Client connection from:", remote_addr)
                                                print("Sending: ", file)
                                                with open(file, 'rb') as f:
                                                    data = f.read(1024)
                                                    while(data):
                                                        print("sending", data)
                                                        cl.sendall(data)
                                                        data = f.read(1024)
                                                print("Done Sending")
                                                cl.close()
                                        Z 1 Reply Last reply Reply Quote 1
                                        • Z Offline
                                          zceld @seb
                                          import select
                                          #Setup WiFi AP
                                                      ssid='Gateway1',
                                          # Bind to the port
                                          port = 12345
                                          s = socket.socket()
                                          s.listen(1)
                                              for s in readable:
                                                      data = f.read(1024)
                                                      while(data):
                                                          cl.sendall(data)
                                                          data = f.read(1024)
                                                  cl.close()
                                          hi, forgive me for the delay, yesterday I could not look at it, today was the first thing I've done and has given a failure on the server.
                                          • sebS Offline
                                            seb @zceld
                                            @zceld
                                            Did you create a test.txt file on your device too? the server reads the file test.txt and client writes to a file called test.txt
                                            • 1
                                            • 2
                                            • 1 / 2
