    First time user: no serial port on Mac?
    lopy
    9 Posts 3 Posters 1.2k Views 3 Watching
    • dwsD Offline
      dws
      Atom plugin is saying "found 0 serialports". In terminal on Mac, 'ls /dev/tty.usb' returns nothing. Expansion board software upgrade fails (I think because there's no serial port.) Reboot doesn't help. So this is more of a Mac question but I figured I would ask here since most people having serial port issues on macs are doing microcontroller development, it seems.
      i've also installed the FTDI drivers but that's not helping.
      thanks.
      J 2 Replies Last reply Reply Quote 0
        jmarcelino @dws
        Hi @dws
        Can you try a different microUSB cable? Sounds like you’re using a power only one
        dwsD 1 Reply Last reply Reply Quote 0
        • dwsD Offline
          dws
            jmarcelino @dws
            @dws The device file only appears when the serial device is detected.
            That’s why it sounds like the USB cable is power only, doesn’t support data
            • dwsD Offline
              dws @jmarcelino
              @jmarcelino That didn't change anything.
              But shouldn't I see a usbserial entry of some kind upon doing the following?
              ls /dev/tty.usb*
              I'm not seeing anything. Or does the port only appear when a device is plugged in?
                robert-hh @dws
                @dws The port only appears when the device is plugged in with a proper cable.
                  jmarcelino @dws
                  @dws
                  Which expansion board do you have ?
                  Should say on the bottom, v2 or v3?
                    robert-hh @jmarcelino
                    @jmarcelino Is there a new expansion board?
                    • dwsD Offline
                      dws
                      finally got it working, had to try three cables i had. i didn't realize the world had so many power-only usb cables, unmarked as such.
                      Thanks!
