Failed 50% of the time to send data!? LORA
  • Im trying to learn how this works.... I dont get it still...
    It wont work, I was thinking it has to do with the recv part,
    maybe it has not the time to handle the bytes that are sent to the lopy.
    from network import LoRa
    import os
    import gc
    #os.uname()
    #os.getcwd() # Check where in the filesystem you are
    for cycles in range(1): # stop after 1 cycles
    lora = LoRa(mode=LoRa.LORA,tx_power = 14, sf = 7, frequency=863000000)
    s.setblocking(False)
    gc.enable()
    i = 0
    failed = 0
    counter_sent = 0
    counter_received = 0
    #s.send("Got data from Stefan over LoRa: {}".format(i))
    s.send(bytes([
    			 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,19,20,21,22,23,24,25,26,27,28,29,30,31,32,
                 33
    			 ])) # = 34 bytes
    data = s.recv(64)
    print(data)
    counter_sent+=1
    print('Sent Data: {}'.format(counter_sent))
    if data:
        print(data)
        print('Received Data: {}'.format(data))
        counter_received+=1
        print('Received Data: {}'.format(counter_received))
        print('Successful data received: {}%'.format(counter_received/counter_sent))
        print(' ')
        print(' ')
        failed +=1
        print('Got no data: {}'.format(failed))
        print('Unsuccessful data received: {}%'.format(failed/counter_sent))
        pycom.rgbled(0x7f0000)
    time.sleep(0.25)
    The received part:
    from machine import UART
    import gc
    Enable garbage collection
    #time.sleep(2)
    #gc.enable()
    #Counters and Declarations
    i = 0
    counter_failed = 0
    counter_sent = 0
    UART_RX_counter = 0
    UART_TX_counter = 0
    UART_RX_Failed = 0
    UART_TX_Failed = 0
    arr_size = 0
    #While loop for UART and LoRa
    #if uart.write('hello'):
    #UART_TX_counter=+ 1 #Successful TX Counter
    #print('Sent over UART: {}'.format(UART_TX_counter))
    #UART_RX = uart.read(5) # read up to 5 bytes
    #if UART_RX:
    #print('Received over UART: {}'.format(UART_RX))
    #UART_RX_counter =+ 1 #Successful RX Counter
    #print('Successful UART received: {}'.format(UART_RX_counter))
    #else:
    #UART_RX_Failed =+ 1 #Failed RX Counter
    #print('Did not get anything over UART: {}'.format(UART_RX_Failed))
    #else:
    #UART_TX_Failed =+ 1 #Failed TX Counter
    #print('Did not send over UART: {}'.format(UART_TX_Failed))
    i+=1
    arr_size += 1
    arr = bytearray(arr_size)
    #s.send("Got data from Jonathan over LoRa: {}".format(i))
    data = s.recv(64)
    #arr = data #Inserts Data received from LoRa
    #print('Array: {}'.format(arr))
    #print(' ')
    counter_sent+=1
    print('Success {}%'.format(counter_received/counter_sent))
    print(' ')
    print('Failed {}%'.format(counter_failed/counter_sent))
    if data:
        print(data)
        counter_received+=1 #Counter over Successful Received Data over LoRa
        #print('Received Data: {}'.format(counter_received))
        if s.send(data):
            print('Sent data')
        #pycom.rgbled(0x007f00) # green
        print(' ')
    else: #Unsuccessful data received over LoRA
        print(' ')
        counter_failed +=1
        #print('Got no data over LoRa: {}'.format(failed))
        #pycom.rgbled(0x7f0000)
    time.sleep(0.25)
