    GPS time from PyTrack
    pytrackrtcgps time
    17 Posts 5 Posters 3.5k Views 5 Watching
    • sebS Offline
      seb @jmpratt
      @jmpratt
      http://www.quectel.com/UploadImage/Downlad/Quectel_L76-L_I2C_Application_Note_V1.0.pdf
        jmpratt @seb
        @seb Does Pycom have any example code that uses the GPS on the PyTrack? All I can find is the code that uses the accelerometer.
        • sebS Offline
          seb @jmpratt
          @jmpratt
          Check https://github.com/pycom/pycom-libraries
            jmpratt @seb
            @seb Got it. Thanks!
              jmpratt
              Ok, I'm confused. Here's a link for a project using the PyTrack with the micropyGPS module: https://github.com/ozeta/iot-gps-receiver. If the PyTrack uses I2C to communicate with the GPS chip, how can micopyGPS communicate with the chip via the UART?
              • sebS Offline
                seb @jmpratt
                @jmpratt
                I see no mention of UART in the linked code
                  jmpratt @seb
                  @seb It looks like he's using both the micropyGPS and L76GNSS modules, which doesn't make any sense to me. Here he talks about seeing output on a UART with a PyTrack and the micropyGPS module: https://github.com/inmcm/micropyGPS/issues/7
                  Is he using the L76GNSS module to pull a NMEA sentence and then send it to the micropyGPS module for handling?
                  Anyone know of a way to contact an author on GitHub?
                  robert-hhR sebS 2 Replies Last reply Reply Quote 0
                    robert-hh @jmpratt
                    @jmpratt said in GPS time from PyTrack:
                    Raise an issue, then the owner will be notified.
                    • sebS Offline
                      seb @jmpratt
                      @jmpratt
                      The L76GNSS library provided by pycom reads the NMEA sentences via I2C, there is no UART involved. The linked to code uses L76GNSS to get the sentenaces, and then micropyGPS to parse them
                        jmpratt @seb
                        @seb Ok. Thanks for the confirmation. I appreciate the help.
                          andrethemac @jmpratt
                          @jmpratt I've had the same question, and was looking for a library that didn't use to much memory. So I wrote it myself (based upon the default library and @Neuromystix idea's. https://github.com/andrethemac/L76GLNSV4
                          best regards
                            jmpratt @andrethemac
                            @andrethemac Thanks for letting me know! Your library is just what I was looking for.
