    [SOLVED] Unable to import from 'network'
    librarynetworkvs code pymakrlopy
    6 Posts 3 Posters 2.3k Views 4 Watching
      CBaudrit
      Hi, I'm an ultra begginer (just started yesturday), I have a LoPy on a Pysense. I wanted to test the LoRaMAC but the imports of LoRa from network don't workThis is my code right now.
      I don't know If my project is well set or else, If I can take any advice to make it work I would thank you.
      Sorry if I didn't explained my problem well, I'm french, but I hope you understood
      • sebS Offline
        seb
        network is a library built into our firmware, the error you are seeing is from visual studio code, it cannot find a network python module, so it complains. If you upload your code to the module will be successfully imported.
          CBaudrit
            CBaudrit @seb
            @seb Alrig thank you it worked indeed ! I have another question, when I try to setup LoRa region like this it says that LoRa has no attribute EU868. How can I fix that ?
              robert-hh @CBaudrit
              @cbaudrit Are you sure that you are using the most recent firmware?
                CBaudrit @robert-hh
                @robert-hh Hello, I updated the firmware and it seems to work, thank you ! Can't belive I didn't do this step ...
                With your input, this post could be even better ๐Ÿ’—
