threading error (NameError: name 'xxx' is not defined)
  • hi all,
    I am trying to make a Class that merges L76GNSS and micropyGPS. I would like to create a thread to feed the micropyGPS object with NMEA data in the background.
    My code is here; https://github.com/gregcope/L76micropyGPS.
    Basically;
    class L76micropyGPS:
        def __init__(self, my_gps, pytrack=None, sda='P22', scl='P21', timeout=None):
        <snippage>
        # start thread feeding microGPS
            _thread.start_new_thread(feedMicroGPS, '')
        def feedMicroGPS(self):
           # <snippage>
                # get some NMEA data
                someNmeaData = self.i2c.readfrom(GPS_I2CADDR, 128)
                print(" feedGps_thread - gpsChars recieved : {}".format(len(someNmeaData)))
                # Pass NMEA data to micropyGPS object
                for x in someNmeaData:
                    self.my_gps.update(x)
    However I get this error;
    File "main.py", line 21, in <module>
    File "/flash/lib/L76micropyGPS.py", line 41, in init
    NameError: name 'feedMicroGPS' is not defined
    What I am doing wrong?
  • Functions and methods are actually different things and exist in different scopes.
    You can't look up a method by name without the self. (or similiar) prefix. Unless you bind it to another name in the current scope.
    The same applies to class methods.
  • Brilliant. Thanks. Now fails much further on!
    I had assumed that as methods in python are declared as functions that this should just work(tm).
    Thanks again.
  • @gregcope you call _thread.start_new_thread(feedMicroGPS, '') can't find feedMicroGPS which is to be expected, it's definition is not in the scope of the init method.
    You should either be using self.feedMicroGPS or cls.feedMicroGPS (if it where a class method).
    The examples use a function not a method.
