    Activation Lopy with TTN network using OTAA method
    lopyotaa
    15 Posts 4 Posters 3.4k Views 4 Watching
      asavvin
      Hello!
      Still unclear for me how I can connect Lopy to TTN network using OTAA method.
      I was able to get connection only using ABP method w/o problem but OTAA have never worked for me.
      Please advice.
      Thank you
      J A 2 Replies Last reply Reply Quote 0
        jmarcelino @asavvin
        Hello @asavvin
        What kind of gateway do you have?
        Also what's your country/LoRa region?
        A O 2 Replies Last reply Reply Quote 0
          asavvin @jmarcelino
          @jmarcelino
          I am @North America and I am using
          TTN Gateway https://shop.thethingsnetwork.com/
          and Lopy
          Thank you
          • O Offline
            oorrab
            • O Offline
              oorrab @jmarcelino
              @jmarcelino - similar issue, but in AUS
              Failing to connect LoPy1 node to TTN in Australia (Adelaide) with OTAA. New to LoRa and LoPy so have plenty of unknowns :)
              Haven't managed to find a definite LoPy/TTN setup description for AU915 that works, but am attempting to set frequencies/channel-plan as per;
              https://www.thethingsnetwork.org/forum/t/ttn-australian-communities/4068
              os.uname()
              (sysname='LoPy', nodename='LoPy', release='1.17.3.b1', version='v1.8.6-849-83e2f7f on 2018-03-19', machine='LoPy with ESP32', lorawan='1.0.2')
              If I delete all channels and re-add, lora.join with timeout=0 does not return (appears to hang). Deleting extra channels and updating those needed appears to be OK.
              Is there a way of confirming all channel settings?
              Trying to spec a dr_max > 6 (for AU) gives a value error - is this expected, and does it matter for a basic join?
              main.py as follows;
              from network import LoRa
              import binascii
              lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915, adr=False, tx_retries=0, device_class=LoRa.CLASS_A)
              for i in range(16, 65):
                  print("Removing channel:", i)
                  lora.remove_channel(i)
              for i in range(66, 72):
              print("Adding channels...")
              for i in range(8, 16):
                  print("Adding channel:", i)
                  f = 915200000 + i * 200000
                  print("Frequency:", f)
                  lora.add_channel(i, frequency=f, dr_min=0, dr_max=3)
              print("Adding channel 65")
              f = 917500000
              lora.add_channel(65, frequency=f, dr_min=4, dr_max=4)
              for i in range(0, 8):
                  print("Adding channel ", i)
                  f = 923300000 + i * 600000
                  lora.add_channel(i, frequency=f, dr_min=0, dr_max=6)
              app_eui = binascii.unhexlify('70B3DAAAAAA0BBA1')
              app_key = binascii.unhexlify('BC1186924E6EAAAAAAAAE995921392C7')
              while not lora.has_joined():
                  time.sleep(2.5)
                  print('Not yet joined...')
              Also tried the above with the channel removes only (no adds to try the defaults) with no avail.
              Any advice on troubleshooting this further? Have tested on several gateways and driven pretty close so shouldn't have a range issue. Node running with PyCom antenna.
              As an aside - it would be awesome to add a LoRa.AU915.TTN to handle this - looks like the Aus TTN community is fairly well coordinated on this sub-band2 setup. Perhaps a non-issue if there is a solid LoPy-Aus-TTN setup guide somewhere. I'll create one if I can get to the bottom of it!
                asavvin
                search over the forum. Still unclear if this is possible to use OTAA activation for US915 Lopy with TTN gateway. Does anybody have success?
                  jimpower @oorrab
                  @oorrab said in Activation Lopy with TTN network using OTAA method:
                  f = 917500000
                  I could be wrong but looking at your code adding the channels back in your sub band 2 should be ch 8-15 and they start at 916.8 - 918.2, yours looks like you are starting from 915.2 try adjusting these and let us know your results.
                  O 1 Reply Last reply Reply Quote 0
                    asavvin
                    I am in US915
                    • O Offline
                      oorrab @jimpower
                      Thanks for the reply @jimpower
                      I put in the print statements (output below) to check the maths/python, but can easily be missing something radio-esque! Indeed, these are spec'd for gateways at;
                      https://www.thethingsnetwork.org/forum/t/ttn-australian-communities/4068/9
                      The node config should replicate right? Nothing to switch as a node vs gateway?
                      AU ISM 915
                      Ch# | direc | f/MHz | BW/kHz | data rate
                      8 | up | 916.8 | 125 | DR0 - DR3
                      9 | up | 917.0 | 125 | DR0 - DR3
                      10 | up | 917.2 | 125 | DR0 - DR3
                      11 | up | 917.4 | 125 | DR0 - DR3
                      12 | up | 917.6 | 125 | DR0 - DR3
                      13 | up | 917.8 | 125 | DR0 - DR3
                      14 | up | 918.0 | 125 | DR0 - DR3
                      15 | up | 918.2 | 125 | DR0 - DR3
                      65 | up | 917.5 | 500 | DR4
                      0 | down | 923.3 | 500 | DR8 - DR13
                      1 | down | 923.9 | 500 | DR8 - DR13
                      2 | down | 924.5 | 500 | DR8 - DR13
                      3 | down | 925.1 | 500 | DR8 - DR13
                      4 | down | 925.7 | 500 | DR8 - DR13
                      5 | down | 926.3 | 500 | DR8 - DR13
                      6 | down | 926.9 | 500 | DR8 - DR13
                      7 | down | 927.5 | 500 | DR8 - DR13
                      Adding channels...
                      Adding channel: 8
                      Frequency: 916800000
                      Adding channel: 9
                      Frequency: 917000000
                      Adding channel: 10
                      Frequency: 917200000
                      Adding channel: 11
                      Frequency: 917400000
                      Adding channel: 12
                      Frequency: 917600000
                      Adding channel: 13
                      Frequency: 917800000
                      Adding channel: 14
                      Frequency: 918000000
                      Adding channel: 15
                      Frequency: 918200000
                      Adding channel 65
                      Frequency: 917500000
                      Adding channel 0
                      Frequency: 923300000
                      Adding channel 1
                      Frequency: 923900000
                      Adding channel 2
                      Frequency: 924500000
                      Adding channel 3
                      Frequency: 925100000
                      Adding channel 4
                      Frequency: 925700000
                      Adding channel 5
                      Frequency: 926300000
                      Adding channel 6
                      Frequency: 926900000
                      Adding channel 7
                      Frequency: 927500000
                        jimpower @oorrab
                        @oorrab I don't use TTN, I deploy my own gateways which operate of frequencies outside of TTN for obvious reasons.
                        My node setup "up" channels replicate my Gateway 'RX" channels, if the mote or node is broadcasting on any channels outside of what the gateway is set to listen on then it will fall on deaf ears so to speak.
                          asavvin @asavvin
                          @asavvin said in Activation Lopy with TTN network using OTAA method:
                          Hello!
                          Please advice.
                          Thank you
                          Finally I was able to get connection Lopy using OTAA with TTN gateway in US915.
                          • O Offline
                            oorrab @asavvin
                            Hi @asavvin - could you share your code and firmware version?
                            Might have some differences here in AUS but would be good to know a working baseline and rule out some unknowns.
                              asavvin
                              @oorrab
                              Hi
                              I used Pycom Lopy with latest firmware. TTN gateway with original firmware.
                              import struct
                              import binascii
                              lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.US915)
                              dev_eui = binascii.unhexlify('xxxx')
                              app_eui = binascii.unhexlify('xxxx')
                              app_key = binascii.unhexlify('xxxx')
                              for channel in range(0, 72):
                              lora.add_channel(channel, frequency=903900000, dr_min=0, dr_max=3)
                              join a network using OTAA
                              lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=4)
                              wait until the module has joined the network
                              join_wait = 0
                              time.sleep(2.5)
                              if not lora.has_joined():
                              print('Not joined yet...')
                              join_wait += 1
                              if join_wait == 5:
                              lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=0)
                              join_wait = 0
                              break
                              create a LoRa socket
                              set the LoRaWAN data rate
                              s.setsockopt(socket.SOL_LORA, socket.SO_DR, 0)
                              make the socket blocking
                              s.setblocking(False)
                              time.sleep(5.0)
                              for i in range (200):
                              pkt = b'PKT #' + bytes([i])
                              print('Sending:', pkt)
                              s.send(pkt)
                              time.sleep(4)
                              rx, port = s.recvfrom(256)
                              if rx:
                              print('Received: {}, on port: {}'.format(rx, port))
                              time.sleep(6)
                              • O Offline
                                oorrab @asavvin
                                @asavvin interesting you set all the channels to the same frequency. Something for me to try to help narrow this down. Frequencies different in AUS but his may take LoPy complexity out of the equation to make progress....
                                  asavvin @oorrab
                                  @oorrab
                                  in application log I can see channels actually keep changing starting from 9039...
