Sending data to server using MQTT
Hello Team,
Am using MQTT to send sensor data to server, i have included mqtt.py library and am running the attached code in the atom but getting the following error,
File "<stdin>", line 23, in <module>
File "mqtt.py", line 56, in connect
OSError: -1Kindly help with this where am doing wrong. Please reply as soon as possible.
Thank You
[0_1524203120867_sub.py](Uploading 100%)
@timh
Ok, i have connected the fipy to our wifi network & it is connected successfully, and also checked the ip address address and ping fipy is working.
@nazz you need stablish that your fipy is actually connected to the Wifi network, has got a valid IP/netmask etc from your DHCP server. These are basic network tests you should perform before thinking about problem with high level libraries like MQTT. Once you have established you have a working network connection then start looking at your code.
Another way of checking is trying to telnet or ftp to your FiPy from your PC.
I did not understand clearly, ping fipy means , do i need to do
ping 192.168.4.1 into my computer??
@nazz ok, but do you have a valid network connection. Can you ping the fipy for instance.
Yes, right now am using my computer as broker and i have setup mosquitto in it which is listing on port 1883, below is the response
[root@localhost /]# sudo netstat -tlnp | grep mosq
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 7918/mosquitto
tcp6 0 0 :::1883 :::* LISTEN 7918/mosquittoIn code i have given my computer ip address, but also not working.
@nazz have you confirmed that you have a valid network connection, (for instance can resolve DNS names) and the MQTT broker you are connecting to is listening on port 1883. Some are listening on 8883 and require TLS.
Thank you for your response, i dint get what does this line means " unless you are running a broker on the FiPy which I doubt" , means in case we are running subscriber code on fipy??
And also in this line "MQTTClient("fipy", "localhost", port=1883)" , i have changed the localhost to respective ip address where i want to send the data, but still same error.
Can you please help me where am going wrong.
Thank You
At the moment your MQTT connection is attempting to connect to itself.
MQTTClient("fipy", "localhost", port=1883)unless you are running a broker on the FiPy which I doubt, you need to have the name or IP address of the MQTT server you wish to connect to.
Sorry for posting again , this is the same issue , Am using MQTT to send sensor data to server, i have included mqtt.py library and am running the below code in the atom but getting the following error,
OSError: -1CODE:
from network import WLAN
from mqtt import MQTTClient
from pysense import Pysense
from LTR329ALS01 import LTR329ALS01
import osdef settimeout(duration):
passwlan = WLAN(mode=WLAN.STA)
wlan.antenna(WLAN.EXT_ANT)
wlan.connect("ssid", auth=(WLAN.WPA2, "password"), timeout=5000)while not wlan.isconnected():
machine.idle()print("Connected to Wifi\n")
client = MQTTClient("fipy", "localhost", port=1883)
client.settimeout = settimeout
client.connect()while True:
print("Sending ON")
py = Pysense()
lt = LTR329ALS01(py)
print("Light (channel Blue lux, channel Red lux): " + str(lt.light()))
client.publish("/lights", str(lt.light()))
print("Battery voltage: " + str(py.read_battery_voltage()))
print("Sending OFF")
client.publish("/lights", str(py.read_battery_voltage()))
client.disconnect()Kindly help with this where am doing wrong. Please reply as soon as possible.
Thank You
