    Using photoresistor with 10kohm resistance
    sensorselectronicslightsensorphotoresistor
    2 Posts 2 Posters 671 Views 2 Watching
    • M Offline
      Matthew
      I'm new here, a few hours ago i've received the fipy and im trying to get a value by the photoresistor,
      the white cable between the photoresistor and resistor goes to pin 16 but i always get the value of 4095.0 even if i cover the photo or point it with the torch
      then the red cable to 3V3 and black to GND
      i've read that maybe this is caused by an incorrect time.sleep()
      can someone pleas help me and explain me whats wrong?
      thank you
      from machine import Pin
      adc = machine.ADC()
      apin = adc.channel(pin='P16')
      def reading():
         avg = 0
         _AVG_NUM = const(100)
         for _ in range (_AVG_NUM):
             avg += apin()
         avg /= _AVG_NUM
         return(avg)
          analog_val = reading()
          print(analog_val)
          pass
        livius @Matthew
        @matthew
        look at attenuation
        https://docs.pycom.io/chapter/firmwareapi/pycom/machine/ADC.html#adcchannel--pin-attnadcattn0db
        try ADC.ATTN_11DB
