    LoRa-MAC (Raw LoRa)
    adafruitlopyloramac
    3 Posts 2 Posters 908 Views 2 Watching
    • V Offline
      Vicky_
      hello. I follow this tutorial to send data using LoRa MAC
      I received this:
      alt text
      how can I get rid of the b'0.1'? I want 0.1 only because I am publishing this data to cloud.
      I received this in cloud.
      alt text
      how to change this coding:
      s.setblocking(False)
      some_number = s.recv(64)
      client.publish(topic=AIO_RANDOMS_FEED, msg=str(some_number))
      Also I wanna ask how far it can goes? I searched but I cant find any documentation about the distance travel for LoRa-MAC.
      Any help would be appreciated. Thanks!
        robert-hh @Vicky_
        @vicky_ you can use decode to get ride of the b
        b'0.1'.decode() gets '0.1", so you code would look like
        client.publish(topic=AIO_RANDOMS_FEED, msg=some_number.decode())
        The distance you can achieve with Raw LoRa is the same as with LoRa-MAC, because it is a property of the RF hardware. It all depends on proper RF design of your devices box, antennas in the mote and in your gateway. So, best case are a 5-10 km outdoors, fair case is about 3km, with a sound gateway antenna outdoors, no lower limit for the worst case.
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          Vicky_ @robert-hh
          @robert-hh Thanks! You saved my day again.
