    Pycom SPI connection for Expansion Board 2.0
    spiexpansion boardlopye-ink display m
    2 Posts 2 Posters 703 Views 2 Watching
      asavvin
      Hello!
      What will be correct pins on pycom Expansion Board 2.0 board to connect via SPI E-Ink display module
      SYMBOL DESCRIPTION
      VCC 3.3V
      GND Ground
      DIN SPI MOSI pin
      CLK SPI SCK pin
      CS SPI chip selection, low active
      DC Data/Command selection (high for data, low for command)
      RST External reset, low active
      BUSY Busy status output, low active
      Thank yuo
        jmarcelino @asavvin
        Hi @asavvin
        Other than 3.3V and GND there aren't any fixed set of pins for that, it's whatever the code you use expects.
        For example in my case I used these
        RST = Pin('P19')
        DC = Pin('P20')
        BUSY = Pin('P18')
        CS = Pin('P4')
        CLK = Pin('P21')
        DIN = Pin('P22')
        But you'll need to use whatever your code is set to.
