    Where do you start or find at least example code?
    sipygeneralpysense
    3 Posts 3 Posters 983 Views 3 Watching
    • F Offline
      freddy
      I just learned coding in python to make a prototype for a simple measuring device.
      I wanted to make a quick program that measures al the sensor data on the pysense and saves it on a SD-card.
      But i don't know where to start? Are there tutorials?
      What do i have to import, what are he names of the sensors?
      I'm close to throwing the whole thing away, there is no simple starting point for an absolute beginner in this field.
      • X Offline
        Xykon administrators @freddy
        @freddy I suggest you start here: https://docs.pycom.io/chapter/pytrackpysense/ and go through all the chapters of that section. It will ultimately bring you to this example code https://github.com/pycom/pycom-libraries/blob/master/pysense/main.py which shows how to use each sensor.
        Christian Ehlers
          smbunn
          @freddy I have some Pysense code to send almost all of it over LoRa. Might be useful as a starting point. It is on GitHub at
          https://github.com/smbunn/FiPy in the python program 'sense.py' and the latest copy is pasted below.
          # See https://docs.pycom.io for more information regarding library specifics
          from network import LoRa
          #import config
          from pysense import Pysense
          from LIS2HH12 import LIS2HH12
          from SI7006A20 import SI7006A20
          from LTR329ALS01 import LTR329ALS01
          from MPL3115A2 import MPL3115A2,ALTITUDE,PRESSURE
          import time   # import library for delay times
          import binascii
          import struct
          import ujson
          # Colors
          off = 0x000000
          red = 0xff0000
          green = 0x00ff00
          blue = 0x0000ff
          yellow = 0xffff00
          # Initialize LoRa in LORAWAN mode.
          # Set up KotahiNet channels
          lora.add_channel(0, frequency=864862500, dr_min=0, dr_max=5)
          lora.add_channel(1, frequency=865062500, dr_min=0, dr_max=5)
          lora.add_channel(2, frequency=865402500, dr_min=0, dr_max=5)
          lora.add_channel(3, frequency=865602500, dr_min=0, dr_max=5)
          lora.add_channel(4, frequency=865985000, dr_min=0, dr_max=5)
          lora.add_channel(5, frequency=866200000, dr_min=0, dr_max=5)
          lora.add_channel(6, frequency=866400000, dr_min=0, dr_max=5)
          lora.add_channel(7, frequency=866600000, dr_min=0, dr_max=5)
          # Turn off hearbeat LED
          dev_addr = struct.unpack(">l", binascii.unhexlify('00 70 C3 4D'.replace(' ','')))[0]
          nwk_swkey = binascii.unhexlify('1BFE9C81AD35B39019244D155CE31D88'.replace(' ',''))
          app_swkey = binascii.unhexlify('045ABBEFE974D3E257AC31522E8E837B'.replace(' ',''))
          # join a network using ABP (Activation By Personalization)
          # create a LoRa socket
          # set the LoRaWAN data rate
          s.setsockopt(socket.SOL_LORA, socket.SO_DR, 0)
          # Builds the bytearray to send the request
          py = Pysense()
          si = SI7006A20(py)
          lt = LTR329ALS01(py)
          li = LIS2HH12(py)
          for count in range (2000):
              print("Count=", count)
              vt = py.read_battery_voltage()
              print("Battery voltage: " +str(vt))
              dew = si.dew_point()
              print("Dew point: "+ str(dew) + " deg C")
              mp = MPL3115A2(py,mode=ALTITUDE) # Returns height in meters. Mode may also be set to PRESSURE, returning a value in Pascals
              print("MPL3115A2 temperature: " + str(mp.temperature()))
              temp1 = mp.temperature()
              alt1 = mp.altitude()+100.0
              print("Altitude: " + str(alt1))
              mpp = MPL3115A2(py,mode=PRESSURE) # Returns pressure in Pa. Mode may also be set to ALTITUDE, returning a value in meters
              press1 = mpp.pressure()
              print("Pressure: " + str(press1)) #Pressure does not work too well
              temp2 = si.temperature()
              hum1 = si.humidity()
              print("Temperature: " + str(temp2)+ " deg C and Relative Humidity: " + str(hum1) + " %RH")
              t_ambient = 24.4
              relhum = si.humid_ambient(t_ambient)
              print("Humidity Ambient for " + str(t_ambient) + " deg C is " + str(relhum) + "%RH")
              print("Light (channel Blue lux, channel Red lux): " + str(lt.light()))
              acct = li.acceleration()
              acc1 = acct[0]
              acc2 = acct[1]
              acc3 = acct[2]
              roll1 = li.roll()
              pitch1 = li.pitch()
              print("Acceleration: " + str(acc1))
              print("Roll: " + str(roll1))
              print("Pitch: " + str(pitch1))
              # Flash the light every time a payload is sent
              pycom.rgbled(blue)
              time.sleep(0.5)
              pycom.rgbled(off)
              time.sleep(0.5)
              pycom.rgbled(red)
              time.sleep(0.5)
              pycom.rgbled(off)
              data = bytearray(48)
              data[0:4] = bytearray(struct.pack(">i", count))
              data[4:8] = bytearray(struct.pack(">f", vt))
              data[8:12] = bytearray(struct.pack(">f", dew))
              data[12:16] = bytearray(struct.pack(">f", temp1))
              data[16:20] = bytearray(struct.pack(">f", alt1))
              data[20:24] = bytearray(struct.pack(">f", press1))
              data[24:28] = bytearray(struct.pack(">f", temp2))
              data[28:32] = bytearray(struct.pack(">f", hum1))
              data[32:36] = bytearray(struct.pack(">f", relhum))
              data[36:40] = bytearray(struct.pack(">f", acc1))
              data[40:44] = bytearray(struct.pack(">f", acc2))
              data[44:48] = bytearray(struct.pack(">f", acc3))
          #    data[48:52] = bytearray(struct.pack(">f", roll1))
          #    data[52:56] = bytearray(struct.pack(">f", pitch1))
              print ('Data = ',count,vt,dew, temp1, alt1, press1, temp2, hum1, relhum, acc1, acc2, acc3, roll1, pitch1 )
              s.setblocking(True)
              s.send(data)  # send buffer to AWS
              print('data sent')
              time.sleep(0.5)
              # get any data received&
              s.setblocking(False)
              data = s.recv(64)
              time.sleep(0.5)
              print(data)  #anything received?time.sleep(20)  # wait time between packets sent
              time.sleep(59)
          Note : I had to comment out the last two float values for roll and pitch as you are limited to 51 bytes when using SF12.
          The Git Hub has my Node--Red implementation which decodes the payload.
          Simon
