    Transmitting a file from a PC to Pycom
    Scheduled Pinned Locked Moved Projects
    pycomtransceiverserial
    2 Posts 2 Posters 1.0k Views 2 Watching
    • R Offline
      Ricardo85
      Hey I am looking for best solution to transmit an audio file from a PC to Pycom and connect the speaker with pycom as an output to listen the audio file from PC
      Your lead on this will be helpful
      note: I don't want to use any SD card I wanted to transmit the audio file directly
        jmarcelino @Ricardo85
        @ricardo85
        I think you’ll need to use the C API and ESP-IDF directly for that, see https://github.com/MrBuddyCasino/ESP32_MP3_Decoder.
        That should run on the Pycom boards
