    ABP connection with Pybytes TypeError: function takes 3 positional arguments but 2 were given
    pybytes
    2 Posts 2 Posters 681 Views 3 Watching
      asavvin
      I am trying to connect Lopy4 with Pytrack to Pybytes.
      I could not define it in config.py correctly.
      configuration defined to use first lora_abp first
      server': 'mqtt.pybytes.pycom.io',
      'network_preferences': ["lora_abp","wifi"],
      ABP defined as:
      abp': {
      'nwk_skey': 'xxx',
      'app_skey': 'xxx',
      'dev_addr': 'xxxxxx'
      getting an error message for 3d parameter
      Using configuration config.py file from /flash folder
      WMAC: 30aea4785f7c
      Firmware: 1.17.5.b2
      File "_main.py", line 95, in <module>
      File "/flash/lib/pybytes.py", line 30, in connect_lora_abp
      MicroPython v1.8.6-849-b9d53b40 on 2018-05-03; LoPy4 with ESP32
      Please advice
        jirkakrepl
        Hi @asavvin, thanks for reporting this issue. We are working on making lora working properly now.
        software developer @ Pycom
