    Lopy4 Guru meditation error
    firmwarelopy4errorguru meditationguru error
    37 Posts 4 Posters 8.9k Views 4 Watching
    • B Offline
      bjsi9 @robert-hh
      @robert-hh Okay, maybe _boot.py or _main.py is corrupted? What could i do about that, any suggestions? Thanks
        robert-hh @bjsi9
        @bjsi9 _boot.py should be OK, because that is executed always. _main.py is inside the frozen bytecode and comes as part of the firmware image. I have my doubts whether that is wrong.
        Did you meanwhile try another (short) cable? Cables and especially connectors can wear.
        B 2 Replies Last reply Reply Quote 0
        • B Offline
          bjsi9 @robert-hh
          @robert-hh Just tried another cable, no luck. Same chrashes, after erase file system and firmware update (done with the updater tool)
          I know its a long shot, but i'm gonna try older version of the updater tool now.
          • B Offline
            bjsi9
            No luck using updater tool 1.13.1.b5
            • B Offline
              bjsi9 @robert-hh
              @robert-hh Hi, quick question. sys, lib and cert folders are all empty when i view them in filezilla FTP (Show hidden files are on). Should these folders be empty?
                robert-hh @bjsi9
                @bjsi9 Yes. They can be empty and are empty on fresh installe devices. lib is used for storing python code of library style. It is also named in uos.path. But that is convention.
                • B Offline
                  bjsi9 @jmarcelino
                  @jmarcelino I've sent my code to you. Do you think its possible that the code, compined with the firmware update, burned the circuit? :) I'm running out of ideas.
                  • B Offline
                    bjsi9
                    I just deleted the boot.py and main.py on one of my LoPy4's via the FTP. When i start the device same chrash every other second.
                      robert-hh @bjsi9
                      @bjsi9 Can you try to erase the flash completely using esptool.py, subcommand erase_flash, and specifying the flash size. That will delete EVERYTHING including configuration and registration options. That will be restored with a pycom update, you can run afterwards.
                      If you have the firmware creating environment set up, you can also run the command:
                      make erase
                      As always, you need to tie P2 to GND to activate the ROM bootloader.
                      B M 2 Replies Last reply Reply Quote 0
                      • B Offline
                        bjsi9 @robert-hh
                        @robert-hh I found the esptool.py on this link, and copied to a file on my desktop: https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/tools/esptool.py
                        I need som guidelines on how to proceed. I think this file goes to the lib folder, and i have to command it from the pymakr.
                        If this is correct, what is the exact command to execute til esptool? Thank you
                          robert-hh @bjsi9
                          @bjsi9 Esptool.py is executed on your PC from the command line (cmd on Windows, terminal on Linux/Max). It is also used internally by the pycom update tool. Just call :
                          python3 esptool.py --help
                          to erase, run
                          python3 esptool.py -p <portname> -c esp32 erase_flash
                          Edit: Esptool is also here: https://github.com/espressif/esptool
                            jmarcelino @bjsi9
                            @bjsi9
                            Could you a test please, go into safe boot so you have control and do
                            pycom.wifi_on_boot(False)
                            To disable WiFi hostAP on boot until activated again.
                            Then let me know if stops crashing.
                            Thanks!
                            B 1 Reply Last reply Reply Quote 2
                            • B Offline
                              bjsi9 @jmarcelino
                              @jmarcelino Success! My two LoPy4's with firmware 1.17.3.b1 and my own code running, no chrashes so far. Haven't tested for more than 10 minutes, but looks fine. Will test SiPy's tomorrow.
                              THANK YOU
                              Update: Still running 1+ hours. Great succes
                                robert-hh @bjsi9
                                @jmarcelino Good to know that WiFi on boot is also disabled on safe boot. Or am I wrong?
                                • B Offline
                                  bjsi9 @robert-hh
                                  @robert-hh I dont think so. Because i can connect to the wifiAP when it is safe boot.
                                  But not now, after this "fix". In both safe boot and normal.
                                  I put the pycom.wifi_on_boot(False) into my main.py. And so far running fine.
                                  • M Offline
                                    MarcosPycom77 @jmarcelino
                                    @jmarcelino do you already searching for a solution or have found it ???? I have the same problem
                                    • M Offline
                                      MarcosPycom77 @robert-hh
                                      • 1
                                      • 2
                                      • 2 / 2
