    Not able to receive downlink data on LoPy
    lopylora
    6 Posts 3 Posters 1.5k Views 4 Watching
      SameerChouksey
      I am using LoPy module to send and receive data over LoRa. I am able to send data successfully but can not receive the LoRa data. Below is the code I am using to receive data. Please check.
      s.setblocking(False)
      while(1):
      data = s.recv(64)
      if(data):
      print("Received data: "+str(data))
      Regards
      Sameer
      robert-hhR R 3 Replies Last reply Reply Quote 0
        robert-hh @SameerChouksey
        @sameerchouksey Some questions:
        • are you using it with TTN or with some other software?
        • is the node set to LORA raw mode or to LoRa WAN mode?
        • What is thr revision of your firmware?
          @sameerchouksey Just a hint:
          start a script with Lora always after a full reset. Soft reset does not reset the Lora device properly.
          Full reset is done by pushing the reset button or calling machine.reset()
            SameerChouksey
            • I am using it with an established LoRa infrastructure and I am able to send data successfully.
            • The node is set to LoRa WAN mode and Device is operating in class C mode.
            • The version info: (sysname='LoPy', nodename='LoPy', release='1.16.0.b1', version='v1.8.6-849-055728a on 2018-02-13', machine='LoPy with ESP32', lorawan='1.0.0')
            P.S. I tried hard resetting the device but it doesn't help.
            Regards,
            Sameer
              @sameerchouksey Did you try to send an uplink message before waiting for a downlink message, according to the LoRa spec?
              You can also try arw LoRa mode, which does not require an uplink message before a downlink message.
              • R Offline
                rskoniec @SameerChouksey
                @sameerchouksey Did you try this example https://docs.pycom.io/chapter/tutorials/lora/lorawan-otaa.html ?
                Especially:
                # make the socket blocking
                # (waits for the data to be sent and for the 2 receive windows to expire)
                s.setblocking(True)
                # send some data
                s.send(bytes([0x01, 0x02, 0x03]))
                # (because if there's no data received it will block forever...)
                # get any data received (if any...)
                data = s.recv(64)
                print(data)
                Also try to upgrade FW to 1.17.x (lorawan have changed to 1.0.2 spec).
