    [Solved]:FiPy socket.connect command
    fipysocket connectpost
    4 Posts 2 Posters 1.7k Views 2 Watching
      DDA
      Thanks a ton @jmarcelino. My problem is solved, added the following right after lte.connect(cid=3), and before s=socket.socket....
      while not lte.isconnected():
          time.sleep(0.25)
      and edited the s.connect to :
      address = socket.getaddrinfo('123.45.67.89',4949) #update with you own server IP,
      print(address)
      s.connect(address[0][-1])
      One minor problem still exists, which I need to look investigate further...maybe tomorrow, the code works once...top to bottom as expected , but if I press "reset" the code executes again as expected, but modem fails to attach...CSQ is 99,99. So far I have seen, if I do power-down-up it works again...but not with reset. Maybe I should run it in loop every 5-10 minutes and check.
      @administrators, @jmarcelino
      Per my last forum topic: https://forum.pycom.io/topic/3201/solved-fipy-cat-m1-connection
      I am able to connect to the Verizon network with my FiPy, but as I modified the code to post data to my server I am getting an unexpected error with s.connect((host,port)). I even tried
      addr=(host,port)
      s.connect(addr) instead of s.connect((host,port)) but same error each time.
      Here is my code block and error
      from network import LTE
      #from socket import *
      import ssl
      import sys
      host='abc.dyndns.org' # replaced actual host name portion with "abc"
      port=4949
      addr=(host,port)
      print('Pycom module and firmware version:%s' % os.uname())
      lte = LTE(carrier="verizon")  # instantiate the LTE object
      lte.attach(band=13)   # attach the cellular modem to a base station, initially it was lte.attch()
      print('FiPY is attached to network')
      time.sleep(0.25)
      pycom.rgbled(0x0000ff) # BLUE LED
      while not lte.isattached():
          print('While not attached yet, signal:%s'%lte.send_at_cmd('AT+CSQ'))
          print('While not attached yet, status:%s '%lte.send_at_cmd('AT+CEER'))
          time.sleep(.25)  # originally 0.25 changed to 5.0 if unseccful in connecting
          lte.attach(band=13)
      lte.connect(cid=3)       # start a data session and obtain an IP address
      print('Connected to LTE-CATM1')
      pycom.rgbled(0x00ff00) # GREEN LED
      s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
      print('Socket created')
      s.settimeout(5.0)
      #s.connect((host, port))  # tried this as well
      s.connect(addr)
      print('Socket Bind Complete....moving to send data  ')
      #s.listen(10)
      s.send('1~660832~05/08/1501:00A0A141E28323C4650~')
      #data=s.recv(1024)
      s.close()
      #print('Received:, repr(data)')
      lte.disconnect()
      lte.dettach()
      pycom.rgbled(0xff0000) # RED LED
      print( " Reached EOP")
      Terminal output:
      >>> os.mkfs('/flash')
      Uploading project (main folder)...
      Reading file status
      Failed to read project status, uploading all files
      Creating dir workspaceStorage
      Creating dir workspaceStorage/bc895fb1973b5d5624b4a2ed2625b38c
      Creating dir workspaceStorage/d0c7d1ef2572273c369bbcf44005cf73
      [1/5] Writing file main.py
      [2/5] Writing file pymakr.json
      [3/5] Writing file settings.json
      [4/5] Writing file workspaceStorage/bc895fb1973b5d5624b4a2ed2625b38c/meta.json
      [5/5] Writing file workspaceStorage/d0c7d1ef2572273c369bbcf44005cf73/meta.json
      ets Jun  8 2016 00:22:57
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:1728
      load:0x4009fa00,len:0
      load:0x4009fa00,len:14584
      entry 0x400a059c
      Pycom module and firmware version:(sysname='FiPy', nodename='FiPy', release='1.17.3.b1', version='v1.8.6-849-83e2f7f on 2018-03-19', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1')
      FiPy is attached to network
      Socket created
        File "main.py", line 36, in <module>
      ValueError: invalid arguments
      MicroPython v1.8.6-849-83e2f7f on 2018-03-19; FiPy with ESP32
      Please advise.Thanks much!!
        DDA
        Also, once connected how do I find the assigned IP address of the FiPy? Use AT+CGPIAF?
          DDA
          @administrators @jmarcelino @daniel @robert-hh @timh
          Any body any suggestions, I am still stuck! Thanks
            jmarcelino @DDA
            Hi @dda
            socket.connect doesn't take a domain name, you need to resolve it first into a tuple like this - (family, type, proto, canonname, sockaddr) - which you can obtain from socket.getaddrinfo()
            In your case doing:
            s.connect(socket.getaddrinfo(addr, port)[0][-1])
            should do what you want.
            There currently isn't a way to obtain your assigned IP address.
