    Deepsleep Pysense button interrupt triggered always
    pysensefipydeepsleepdeepsleep wake
    2 Posts 2 Posters 773 Views 2 Watching
      akshayjames
      Hi
      I am using putting the FiPy to deepsleep mode (with setting up interrupt for the pysense button, P14).
      The board just keeps waken up without pressing the button for deepsleep interrupt.
      The code:
      print("Wake reason:", machine.wake_reason())
      machine.pin_deepsleep_wakeup(pins = ('P14',), mode = machine.WAKEUP_ANY_HIGH, enable_pull = True)
      print('going to sleep')
      machine.deepsleep(20000)
      Output:
      ets Jun  8 2016 00:22:57
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:1728
      load:0x4009fa00,len:0
      load:0x4009fa00,len:14584
      entry 0x400a059c
      Wake reason: (0, None)
      going to sleep
      rst:0x5 (DEEPSLEEP_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      entry 0x400a059c
      Wake reason: (1, [Pin('P14', mode=Pin.IN, pull=Pin.PULL_DOWN, alt=-1)])
      going to sleep
      entry 0x400a059c
      going to sleep
      entry 0x400a059c
      going to sleep
      entry 0x400a059c
      going to sleep
      Disconnected. Press any key to reconnect.
      I tried using P10 with another program and connecting a wire from 3V3 to P10 for interrupt. That works.
      Can anyone check if this problem is just for my Pysense board or is there something I am doing wrong in the code?
        jmarcelino @akshayjames
        @akshayjames
        I think the problem is the button on the Pysense goes low when pressed, not high, so you want to wake up on low.
