FiPy + Pytrack power consumption
Hello!
I want to run the FiPy and Pytrack using a battery, and i need to know what the power consumption is.
Does anyone have any numbers?
All i found in the docs was "The input voltage must be between 3.4V and 5.5V."
Source: https://docs.pycom.io/chapter/datasheets/notes/Thanks!
Hi @turbolego
Power consumption will vary with usage, you can find all the details on the datasheet: https://docs.pycom.io/chapter/datasheets/downloads/fipy-specsheet.pdf
