FiPy Socket Connection Issue (Verizon LTE)
  • I've got an issue where my FiPy cannot seem to open a socket connection on LTE. It works correctly on WiFi. Below is my code. the sequence of wifi() followed by google() succeeds. The sequence of connect() followed by google() fails at the ss.connect().
    I've updated the FiPy firmware and modem firmware to the latest.
    I'm using a Verizon SIM card in the US. It appears that I have a valid LTE connection as the DNS lookup performed by getaddrinfo succeeds.
    from network import LTE
    import ssl
    from network import WLAN
    wlan = WLAN(mode=WLAN.STA)
    lte = LTE()
    def connect():
        print('lte.attach()', end='')
        lte.attach()
        while not lte.isattached():
            print('.', end='')
            time.sleep(0.25)
        print('Connecting to LTE network', end='')
        lte.connect()
        while not lte.isconnected():
            print('.', end='')
            time.sleep(0.25)
        print('LTE is connected')
    def disconnect():
        lte.disconnect();
        lte.dettach();
    def at(s):
        print(lte.send_at_cmd(s))
    def google():
        s = socket.socket()
        ss = ssl.wrap_socket(s)
        i = socket.getaddrinfo('www.google.com', 443)[0][-1]
        print('Connecting to socket...')
        ss.connect(i)
        print('Send...')
        ss.send(b"GET / HTTP/1.0\r\n\r\n")
        print(ss.recv(4096))
        print('Close...')
        ss.close()
    def wifi():
        wlan.init(mode=WLAN.STA, antenna=WLAN.INT_ANT)
        nets = wlan.scan()
        for net in nets:
            if net.ssid == 'Test':
                print('Network found!')
                wlan.connect(net.ssid, auth=(net.sec, 'Test1234'), timeout=5000)
                while not wlan.isconnected():
                    #machine.idle() # save power while waiting
                    print('.', end='')
                    time.sleep(0.5)
                break
    Any ideas?
    connect()
    lte.attach()..........................Connecting to LTE network.LTE is connected
    >>> google()
      File "main.py", line 49, in google
    OSError: -1
    Firmware version info:
    Upgrade completed!
    Here's the current firmware version:
    UE5.0.0.0c
    LR5.1.1.0-33988
    OK
    alt text
  • This post is deleted!
  • I've got an update. Today, I tried updating to the latest Sequans firmware and experienced strange issues. I tried updating to the latest firmware, downgrading to earlier release firmware, still problematic. Leaving the modem at 1.17, I unplugged and left it alone for a while. A few hours later, reconnected and tried running the exact code in this thread. So, at this point, the FiPy firmware and modem firmware are identical to when I first experienced these issues. This time, everything worked. I could successfully open sockets, send receive data, etc.
    This allows me to close out my evaluation of the FiPy modem. It seems there are still some major functional and reliability issues to be resolved from all parties, Monarch/Sequans, Pycom, and Verizon. I'll revisit this in the future and in the interim, drop in on the forums from time to time to see what current user experience has been.
  • I don't know if this is related, but I can only send one AT command before things crash and I need to power cycle the modem. Note, this is after connecting. Before connecting, things seem to be ok (at least, I can send multiple commands):
    Connecting on COM37...
    >>> connect()
    lte.attach()...............Connecting to LTE network....LTE is connected
    >>> at('AT+CNUM')
    +CNUM: "Line 1","+1<redacted>",145
    OK
    >>> at('AT+COPS?')
      File "main.py", line 58, in at
    OSError: the requested operation failed
  • @jmarcelino
    I tried that and it crashes on lte.connect(cid=3):
    >>> connect()
    lte.attach().........................................................................................Connecting to LTE networkTraceback (most recent call last):
      File "main.py", line 19, in connect
    I also tried manually:
    MicroPython v1.8.6-849-83e2f7f on 2018-03-19; FiPy with ESP32
    >>> import socket
    >>> import time
    >>> lte = LTE()
    >>> lte.attach()
    >>> lte.isattached()
    True
    >>> lte.connect(cid=3)
    And specifying the carrier and band:
    >>> Disconnected. Click here to reconnect.
    >>> import socket
    >>> lte = LTE(carrier="Verizon")
    >>> lte.attach(band=13)
    >>> lte.isattached()
    True
    >>> lte.connect(cid=3)
    Note, each of these attempts was carried out after completely power cycling the modem.
  • @marike
    Thanks, can you try using
    lte.connect(cid=3)
    in your code instead?
  • @jmarcelino No, that doesn't help:
    >>> connect()
    lte.attach().............Connecting to LTE network.LTE is connected
    >>> s = socket.socket()
    >>> s.connect(socket.getaddrinfo('www.micropython.org', 80)[0][-1])
    OSError: -1
    With my tests when I establish a network connection using wifi, both SSL and non SSL connections work:
    >>> wifi()
    Network found!
    ................WLAN connection succeeded!
    >>> m = socket.socket()
    >>> m.connect(socket.getaddrinfo('www.micropython.org', 80)[0][-1])
    >>> m.close()
    >>> google()
    Send...
    b'HTTP/1.0 200 OK\r\nDate: Fri, 25 May 2018 21:26:00 GMT\r\nExpires: -1\r\nCache-Control: private, max-age=0\r\nContent-Type: text/html; charset=ISO-8859-1\r\nP3P: CP="This is not a P3P policy! See g.co/p3phelp for more info."\r\nServer: gws\r\nX-XSS-Protection: 1; mode=block\r\nX-Frame-Options: SAMEORIGIN\r\nSet-Cookie: 1P_JAR=2018-05-25-21; expires=Sun, 24-Jun-2018 21:26:00 GMT; path=/; domain=.google.com\r\nSet-Cookie: NID=131=mW-1wvCRrJflp3M55yaXa9U9nArH8BMxRzUjeiTjbrbhCmXsfzilV0Ovo6ariBt7tAQg5o2CEhMahFD2FK6AT5b_t_-YMGVbsbBlas03nAuazTZ_G-2atJYg2U9-WlaV; expires=Sat, 24-Nov-2018 21:26:00 GMT; path=/; domain=.google.com; HttpOnly\r\nAlt-Svc: hq=":443"; ma=2592000; quic=51303433; quic=51303432; quic=51303431;quic=51303339; quic=51303335,quic=":443"; ma=2592000; v="43,42,41,39,35"\r\nAccept-Ranges: none\r\nVary: Accept-Encoding\r\n\r\n<!doctype html><html itemscope="" itemtype="http://schema.org/WebPage" lang="en"><head><meta content="Search the world\'s information, including webpages, images, videos and more. Google has many special features to help you find exactly what you\'re looking for." name="description"><meta content="noodp" name="robots"><meta content="text/html; charset=UTF-8" http-equiv="Content-Type"><meta content="/logos/doodles/2018/celebrating-james-wong-howe-5981428998209536-l.png" itemprop="image"><meta content="Celebrating James Wong Howe" property="twitter:titl'
    Close...
  • @marike
    Can you try a non-SSL connection? Does that help?
