    Pymakr under Linux Fedora. Anyone?
    12 Posts 5 Posters 3.4k Views 5 Watching
      jnc
      Hi
      I'm trying to run Pymakr 1.0.0.b7-1 under Fedora 25 but when i try to start it, I always get the following error:
      jnc@enigma ~ $ pymakr
      Python 2.7.12
      Error in sys.excepthook:
        File "/usr/share/pymakr/modules/pymakr.py", line 145, in excepthook
          import Utilities
        File "/usr/share/pymakr/modules/Utilities/__init__.py", line 62, in <module>
          from PyQt5.Qsci import QSCINTILLA_VERSION_STR, QsciScintilla
      ImportError: No module named Qsci
      Original exception was:
        File "/usr/share/pymakr/modules/pymakr.py", line 368, in <module>
          main()
        File "/usr/share/pymakr/modules/pymakr.py", line 268, in main
          if not Globals.checkBlacklistedVersions():
        File "/usr/share/pymakr/modules/Globals/__init__.py", line 110, in checkBlacklistedVersions
      I've checked the installed packages, and can't figure out what I'm missing:
      jnc@enigma ~ $ dnf list installed *qsci* *pyqt* *qt*
      Failed to synchronize cache for repo 'Dropbox', disabling.
      Last metadata expiration check: 1:16:54 ago on Mon Nov 28 10:45:27 2016.
      Installed Packages
      PyQt4.x86_64                        4.11.4-15.fc25              @fedora
      adwaita-qt-common.noarch            0.4-3.fc25                  @anaconda
      adwaita-qt4.x86_64                  0.4-3.fc25                  @anaconda
      adwaita-qt5.x86_64                  0.4-3.fc25                  @anaconda
      dbusmenu-qt.x86_64                  0.9.3-0.11.20150604.fc24    @koji-override-0
      ibus-qt.x86_64                      1.3.3-11.fc25               @anaconda
      python-qt5.x86_64                   5.7-1.fc25                  @fedora
      python-qt5-rpm-macros.noarch        5.7-1.fc25                  @fedora
      python-qt5-webkit.x86_64            5.7-1.fc25                  @fedora
      python2-qscintilla.x86_64           2.9.3-1.fc25                @fedora
      qt.x86_64                           1:4.8.7-18.fc25             @anaconda
      qt-common.noarch                    1:4.8.7-18.fc25             @anaconda
      qt-settings.noarch                  25-2.fc25                   @anaconda
      qt-x11.x86_64                       1:4.8.7-18.fc25             @anaconda
      qt3.x86_64                          3.3.8b-68.fc25              @fedora
      qt5-qtbase.x86_64                   5.7.0-3.fc25                @anaconda
      qt5-qtbase-common.noarch            5.7.0-3.fc25                @anaconda
      qt5-qtbase-gui.x86_64               5.7.0-3.fc25                @anaconda
      qt5-qtconnectivity.x86_64           5.7.0-2.fc25                @fedora
      qt5-qtdeclarative.x86_64            5.7.0-2.fc25                @anaconda
      qt5-qtenginio.x86_64                1:1.6.1-2.fc25              @fedora
      qt5-qtlocation.x86_64               5.7.0-2.fc25                @fedora
      qt5-qtmultimedia.x86_64             5.7.0-2.fc25                @fedora
      qt5-qtsensors.x86_64                5.7.0-2.fc25                @fedora
      qt5-qtserialport.x86_64             5.7.0-2.fc25                @fedora
      qt5-qtsvg.x86_64                    5.7.0-2.fc25                @fedora
      qt5-qttools-common.noarch           5.7.0-3.fc25                @fedora
      qt5-qttools-libs-clucene.x86_64     5.7.0-3.fc25                @fedora
      qt5-qttools-libs-designer.x86_64    5.7.0-3.fc25                @fedora
      qt5-qttools-libs-help.x86_64        5.7.0-3.fc25                @fedora
      qt5-qtwebchannel.x86_64             5.7.0-2.fc25                @fedora
      qt5-qtwebkit.x86_64                 5.7.0-2.fc25                @fedora
      qt5-qtwebsockets.x86_64             5.7.0-1.fc25                @fedora
      qt5-qtx11extras.x86_64              5.7.0-2.fc25                @fedora
      qt5-qtxmlpatterns.x86_64            5.7.0-2.fc25                @anaconda
      qt5-srpm-macros.noarch              5.7.0-9.fc25                @fedora
      sni-qt.x86_64                       0.2.6-7.fc24                @koji-override-0
      wireshark-qt.x86_64                 2.1.1-2.fc25                @fedora
      Thanks for your help
        abilio @jnc
        Hi @jnc, I've just seen your dump and list (thanks for providing them), and I'm sorry to tell you that at the present time Pymakr doesn't play nice in *nix with Qt5 installed. It's on our list of bugs to fix. Sorry for the inconvenience, and please stay tuned regarding this.
        J N 2 Replies Last reply Reply Quote 0
          jnc
          Hi
          Thanks for your prompt reply; so how should I work with my boards?
          Cheers
            jnc @abilio
            Hi @abilio
            I'm removed the python-qt5 package (plus a bunch of others that were removed automatically). Now, when I try to start pymakr, I get the following:
            Python 2.7.12
            libpng warning: iCCP: known incorrect sRGB profile
            Warning: translation file 'qt_en_US'could not be loaded.
            Using default.
            Warning: translation file 'eric6_en_US'could not be loaded.
            Using default.
            Warning: translation file 'qscintilla_en_US'could not be loaded.
            Using default.
            BackgroundService listening on: 36797
              File "/usr/share/pymakr/modules/Utilities/BackgroundClient.py", line 193, in <module>
                backgroundClient.run()
              File "/usr/share/pymakr/modules/Utilities/BackgroundClient.py", line 178, in run
                'EXCEPTION', '?', [str(exctype), str(excval), tbinfo])
              File "/usr/share/pymakr/modules/Utilities/BackgroundClient.py", line 81, in __send
                self.connection.sendall(header)
              File "/usr/lib64/python2.7/socket.py", line 228, in meth
                return getattr(self._sock,name)(*args)
            socket.error: [Errno 32] Broken pipe
            Any idea?
              abilio @jnc
              @jnc, I guess you need Qt5 for another app, so at present time you can use the classic telnet/FTP combination. You can also try Pymakr in Windows/Mac (they are installed in a semi-portable fashion where Python, Qt and PyQt are self-contained in the same directory).
              If you're willing to try Telnet/FTP in the meantime, I can point you to: https://docs.pycom.io/pycom_esp32/pycom_esp32/general.html . We should have Pymakr playing nicely with Qt5 in the upcoming weeks.
                abilio @jnc
                Ohh @jnc, I see you went into removing Qt5. I see the dump, and seems its failing early in the start process. Can I ask you how comfortable you are around the terminal window? I have some ideas, but I must confirm with you that you can try them.
                  jnc @abilio
                  @abilio I'm very familiar with the terminal window.
                    abilio @jnc
                    Hi @jnc, btw, can you provide me again with the list of the packages you still have installed in the system that are related to Qt, PyQt and python?
                    • B Offline
                      Bajoja
                      Hello, i use Fedora 25 too and i having the same issue, some prediction to correct the bug?
                      • N Offline
                        nextcloud @abilio
                        Hi @abilio ,
                        I get the same error on fedora25, python-qt5 package is removed. Any idea how to solve?
                        Thanks!
                        BackgroundService listening on: 35079
                          Avathar
                          Any news on this? I'm using antergos (arch based) and have the same problem.
                          I don't want to be forced to use windows to program my LoPy ;)
                          Are there any other IDEs to use?
                          EDIT: i just read the announcment that pymakr is EOL, looking forward to a VScode plugin :D
                          • B Offline
                            Bajoja @Avathar
                            @Avathar Pymakr is discontinued, see this for more info.
                            https://forum.pycom.io/topic/635/pymakr-time-of-death-09-02/33
