    Fipy + Pytrack + LTE [hardware bug?]
    fipypytrack
    1 Posts 1 Posters 505 Views 3 Watching
      tealbrains
      I have been testing the Pytrack with a Fipy as well as with a Gpy. The same code is executed on the Fipy and Gpy.
      The GPy + Pytrack combo works, the Fipy + Pytrack combo does not.
      I enable the LTE, connect to the network and sync the RTC via NTP.
      The Fipy does not make it past:
      lte = LTE()
      If I put the Fipy on an expansion board (v3), it works.
      The modem's firmware is 33988 and I have tried the 1.17.3 and the 1.18.0 on the Fipy as well.
      I though that maybe it was a power issue, so I have tried running it with a battery too. No luck.
      Is this a known problem? Any suggestions?
      Thanks!
