    Recovered from modem failure: OSError: AT+SMSWBOOT=3,0
    gpyfirmwareupdatefailuresqnsupgrade
    1 Posts 1 Posters 659 Views 1 Watching
      derefnull
      My pyCom gPy device had an unresponsive lte modem.
      During a failed firmware upgrade, it spit out this exception:
      OSError: AT+SMSWBOOT=3,0 failed!
      Sending basic AT commands appeared to fail as well..
      > import LTE
      > lte=lTE()
      > lte.send_at_command('ATI')
      I recovered the modem by running the script supplied here by @jmarcelino
      #!/usr/bin/env python
      import struct
      import crc
      import stp
      import os
      from machine import UART
      from machine import SD
      FFF_FMT = "<4sIIIIIIIHHIHHIHHHH"
      FFF_SLIM_FMT = "<4sIIIIIIIHHHH"
      FFF_FEATURES_SLIM = 1 << 0
      FFF_MAGIC = "FFF!"
      SFFF_MAGIC = "SFFF"             # Firmware
      SUFF_MAGIC = "SUFF"             # Updater
      TEST_MAGIC = "TEST"             # Test
      DIFF_MAGIC = "DIFF"             # Diff Upgrade
      UPGR_MAGIC = "UPGR"             # Generic raw upgrade
      RASR_MAGIC = "RASR"             # Generic raw rasterize
      def read_rsp(s, size=None, timeout=-1):
          if timeout < 0:
              timeout = 20000
          elif timeout is None:
              timeout = 0
          while not s.any() and timeout > 0:
              time.sleep_ms(1)
              timeout -= 1
          if size is not None:
              rsp = s.read(size)
              rsp = s.read()
          if rsp is not None:
              return rsp
              return b''
      def print_pretty_response(rsp):
          lines = rsp.decode('ascii').split('\r\n')
          for line in lines:
              if line:
                  print(line)
      def wait_for_modem(s, send=True, expected=b'OK'):
              if send:
                  s.write("AT\r\n")
              rsp = read_rsp(s, timeout=50)
              if expected in rsp:
                  print()
                  break
                  print('.', end='', flush=True)
                  time.sleep(0.5)
      def run(file_path, baudrate):
          abort = False
          print('<<< Welcome to the SQN3330 firmware updater >>>')
          if '/sd' in file_path:
              sd = SD()
              time.sleep(0.5)
              os.mount(sd, '/sd')
              time.sleep(0.5)
          blobsize = os.stat(file_path)[6]
          blob = open(file_path, "rb")
          if 'FiPy' in os.uname().sysname:
              pins = ('P20', 'P18', 'P19', 'P17')
              pins = ('P5', 'P98', 'P7', 'P99')
          s = UART(1, baudrate=baudrate, pins=pins, timeout_chars=100)
          s.read()
          # disable echo
          s.write("ATE0\r\n")
          response = read_rsp(s)
      #     print('Entering recovery mode')
      #     s.write("AT+SMSWBOOT=3,0\r\n")
      #     response = read_rsp(s)
      #     if b'OK' in response:
      #         print('Resetting.', end='', flush=True)
      #         s.write('AT^RESET\r\n')
      #         wait_for_modem(s, send=False, expected=b'+SHUTDOWN')
      #         time.sleep(2)
      #         wait_for_modem(s)
      #         s.write("AT\r\n")
      #         s.write("AT\r\n")
      #     else:
      #         raise OSError('AT+SMSWBOOT=3,0 failed!')
      #     time.sleep(1)
      #     s.read()
          print('Starting STP (DO NOT DISCONNECT POWER!!!)')
          s.write('AT+SMSTPU=\"ON_THE_FLY\"\r\n')
          response = read_rsp(s, size=4)
          if response != b'OK\r\n' and response != b'\r\nOK' and response != b'\nOK':
              raise OSError("Invalid answer '%s' from the device" % response)
              blob.close()
          s.read()
          try:
              stp.start(blob, blobsize, s, baudrate, AT=False)
              print('Code download done, returning to user mode')
          except:
              blob.close()
              print('Code download failed, aborting!')
              abort = True
          time.sleep(1.5)
          s.read()
          s.write("AT+SMSWBOOT=1,0\r\n")
          print('Resetting (DO NOT DISCONNECT POWER!!!).', end='', flush=True)
          time.sleep(1.5)
          s.write("AT^RESET\r\n")
          time.sleep(2)
          wait_for_modem(s, send=False, expected=b'+SYSSTART')
          if not abort:
              time.sleep(0.5)
              print('Deploying the upgrade (DO NOT DISCONNECT POWER!!!)...')
              s.write("AT+SMUPGRADE\r\n")
              response = read_rsp(s, timeout=120000)
              time.sleep(1.5)
              time.sleep(2)
              s.write("AT\r\n")
              s.write("AT\r\n")
              time.sleep(0.5)
              s.read()
              print('Upgrade completed!')
              print("Here's the current firmware version:")
              time.sleep(0.5)
              s.read()
              s.write("ATI1\r\n")
              print_pretty_response(response)
      allowing it to run to COMPLETION (even though it appeared to hang for several minutes)
      at the end of completion, the script was able to query the modem for firmware version (it was old)
      I replaced the sqnsupgrade script with the original, and was able to run it to completion!
      >>> import sqnsupgrade
      >>> sqnsupgrade.run('/sd/FIPY_GPY_CATM1_33988.dup', 921600)
      Resetting..
      STP started
      Session opened: version 1, max transfer 8192 bytes
      Sending 5665583 bytes: [########################################] 100%
      Resetting (DO NOT DISCONNECT POWER!!!)..
      Upgrade completed!
      UE5.0.0.0c
      LR5.1.1.0-33988
      OK
