    Correct UART pins and problems
    lopy4uarthoneywellserialexpansion board
    3 Posts 3 Posters 1.1k Views 3 Watching
    • H Offline
      hopkapi
      I've been trying to get a Honeywell HPMA115S0 particulate sensor working with my LoPy4 and expansion board, but even with a modified Python library and lots of trial and error, it still can't read anything (the sensor works fine with a Pi). I want to check which pins I should be using for UART, and if there are any known issues that'd explain the problems I'm having.
      LoPy4 with the latest firmware, expansion board 2.0, USB connected, sensor connected to VIN (it uses 5V power and 3V logic), have tried a variety of pins but it seems like G24 and G11 should be the right ones.
        jhonrob92 Banned
          robert-hh @hopkapi
          @hopkapi If you connect
          G24 aka P3 -> 7
          G11 aka P4 -> 6
          GND -> 8 GND
          Vin -> 2 (5V)
          and run the LoPy from USB. then the electrical conditions shoul be OK, and the device shoudl be accessible via UART 1. SOmetimes the definition of Tx and Rx are reversed, so you may swap P3 and P4. That should not cause any harm to the devices. The UART setting according to the data sheet is baud rate: 9600, databits: 8, stopbits: 1, parity: no
          Some test code would be like:
          from machine import UART
          uart = UART(1, 9600)                         # init with given baudrate
          uart.init(9600, bits=8, parity=None, stop=1) # init with given parameters
              data = uart.readall()
              if data is not None:
                  print(data)
