    New Firmware Development release v1.19.0.b4
    Scheduled Pinned Locked Moved Beta Announcements & Development News
    firmwaredevelopment
    33 Posts 15 Posters 9.9k Views 15 Watching
    • I Offline
      iwahdan
      Hello everyone,
      Development firmware v1.19.0.b4 is now released. you can now download the firmware to pycom devices via the firmware updater or download the source from here.
      Important: This firmware has support for both FatFS and LittleFS and will default to using FatFS unless you set the correct File System when flashing the board. For this reason, you can only flash this firmware using the new beta firmware updater 1.15.2.b0 or by downloading the firmware file manually and flashing it via the local file option.
      For documentation you can find it here.
      Release Notes:
      Added Feautures:
      • Added RTC memory support
      • Added support for including uasyncio micropython module
      • Added Lora mesh functionality with openthread protocol
      Fixes:
      • Fixed problems with Non-Blocking Sockets
      For new Lora Mesh functionality we added example scripts that you can find here
      Wahdan
      H 1 Reply Last reply Reply Quote 2
        Sympatron
        Interesting additions!
        I have a few questions:
        • The RTC-memory documentation is missing how much data can be saved.
        • Is it a Full Thread Device or just an End Device?
        • I have no experience with OpenThread. Can a LoPy be used as a Border Router to transparently send UDP packets to non-Thread devices e.g. via WiFi? If not at the moment will it be in the future or can this be implemented by oneself? This would be extremely interesting for us, because it would spare us of having to implement something similar.
        • catalinC Offline
          catalin
          Regarding LoRa-Mesh (based on OpenThread) functionality a couple of docs:
          • https://docs.pycom.io/v/development_release/chapter/tutorials/lora/lora-mesh.html <later edit>
          • new Lora methods (.mesh() and .cli()), also the mesh sockets here: https://docs.pycom.io/v/development_release/chapter/firmwareapi/pycom/network/lora.html
          As usual, we need community feedback: what interesting things you want to do with a Lora-Mesh network?
          Catalin,
            Sympatron
            As others have mentioned in the past it would be extremely helpful to have some kind of roadmap. I don't necessarily need fixed dates, but we are trying to use your device commercially and therefore we need to make business decisions.
            If we had known you were working on an OpenThread implementation we could have saved a lot of time developing our own LoRa network protocol.
            • I Offline
              iwahdan @Sympatron
              @sympatron , You can save up to 2KB of data in RTC memory
              Wahdan
              G 1 Reply Last reply Reply Quote 2
                gregcope @iwahdan
                @iwahdan
                Hi. Any docs for this (rtc memory)
                  Sympatron @gregcope
                  @gregcope https://docs.pycom.io/v/d0d9191ca2df10c6ca280de6fd2f11e7c5a18e6f/chapter/firmwareapi/pycom/machine/RTC.html#rtcmemorydata
                  • catalinC Offline
                    catalin
                    hi @Sympatron, I can answer the Openthread questions:
                    • in this release openthread is compiled for FTD( though, no DNS, Commissioner/Joiner role, DTLS, Jam detection, here are include files)
                      • you can (or I can provide) a MTD openthread library build, code is open-source at https://github.com/pycom/pycom-esp-idf/tree/idf_dev
                    • I've been investigating the Border Router issue:
                      • for the moment the UDP packets are not transferred to Wifi
                      • Solution A: (doable by you immediately in a micropy script) you could start and UDP server (bind a socket) on the designated Border Router device, propagate it's IPv6 (RLOC or ML_EID) thru multicast in the whole network, receive all UDP packages and manually take UDP payload to the Wifi socket
                      • Solution B: you can also use lora.cli('prefix add xx::xx') to insert the prefix for out-mesh traffic, then use otIp6ReceiveCallback to filter on Border Router all the IP traffic having that prefix, unpack UDP packets, repack and send on wifi socket; basically some NAT64 needs to be implemented
                      • I would try the solution B, but not sure if we can release sooner than 1 month
                      • for implementing Solution A, take a look here for UDP sockets example: https://github.com/pycom/pycom-libraries/tree/master/lib/lora_mesh
                    Catalin,
                      gregcope @Sympatron
                      @sympatron thanks!
                      • H Offline
                        Harish kumar @iwahdan
                        Hi @iwahdan ! I am using Arduino as a device. And lopy4 as a repeater, where lopy4 has to fetch data from the device and it needs to send to the Gateway(only by lorawan). Is it possible with this ?
                        I am sending OTAA from Arduino to server.
                        Thank you in Advance !
                        • R Offline
                          RodgerG
                          Hi @catalin
                          This LoRaMesh is great and just what I have been looking for!
                          I tried downloading the example file and library and loaded them on to a LoPy4 on a PySense.
                          However, I get a strange error on start up (or reset) as below...
                          Initializing filesystem as LittleFS!
                          LoRa MAC: 70b3d5499625b58c
                            File "main.py", line 23, in <module>
                            File "/flash/lib/loramesh.py", line 98, in led_state
                          OSError: the requested operation is not possible
                          Pycom MicroPython 1.19.0.b4 [v1.9.4-50f84dd] on 2018-07-13; LoPy4 with ESP32
                          >>> mesh.led_state()
                          The call from main.py is as follows
                              mesh.led_state()
                          and the code on line 98 of loramesh.py is the third line of the following method
                              def led_state(self):
                                  """ Sets the LED according to the Thread role """
                                  pycom.rgbled(self.RGBLED[self.state()])
                          When I just call mesh.led_state() from the command line, there is no such error, as you can see from the console log.
                          I tried putting mesh.led_state() in a try-except clause, but still kept getting the same OS error.
                          As a workaround, I have copied RGBLED to main, and replaced
                          mesh.led_state()
                          with
                          pycom.rgbled(RGBLED[mesh.state()])
                          and this works.
                          I cannot see any obviouse reason for the error.
                          • R Offline
                            RodgerG
                            @ catalin
                            Found the problem
                            The example code was missing
                            # Make sure heartbeat is disabled before setting RGB LED
                            pycom.heartbeat(False)```
                            • I Offline
                              iwahdan @Harish kumar
                              @harish-kumar yes it is possible, however you have to make sure that Arduino only use a single frequency, as Pycom devices can only listen on a single frequency, you should be implementing something like that
                              https://docs.pycom.io/chapter/tutorials/lora/lorawan-nano-gateway.html#otaa-over-the-air-activation
                              on Arduino.
                              Wahdan
                              • E Offline
                                egimbernat @RodgerG
                                @rodgerg When pycom.heartbeat is set to true (By default it is), creates a lock around led operations that's because the OSError. Even if you adquire a lock and iterate around led operations on main thread or an volatile thread pycom.heartbeat will have priority when turned on.
                                The solution as you found is to set:
                                When you want to gain control over led, sometimes you may need a very small delay in order the heartbeat lock to release. For example:
                                pycom.heartbeat(False) #Assuming that it was True
                                time.delay(0.05)
                                mesh.led_state()
                                  cmisztur
                                  @iwahdan Thanks. Should importing uasyncio work in this release ?
                                  • I Offline
                                    iwahdan @cmisztur
                                    @cmisztur, We've done some updates in this Dev release to support including the uasyncio lib from micropython.
                                    The uasyncio library is provided by MicroPython under micropython-lib: https://github.com/micropython/micropython-lib/tree/master/uasyncio
                                    Unlike CPython's asyncio library it is splitted into several parts:
                                    • uasyncio.core
                                    • uasyncio.queues
                                    • uasyncio.synchro
                                    • uasyncio.udp
                                    • uasyncio.websocket.server
                                    The uasyncio library relies on the micropython-lib/collections (defaultdict, deque) and logging libraries.
                                    Note: I've updated my Release post as it was wrongly implying that the uasyncio already included in firmware
                                    Wahdan
                                      soulsurfer @iwahdan
                                      @iwahdan - Given the recent change in wording (and the fact that I'm a micropython noob!) are there explicit instructions anywhere on precisely how to "includ[e] uasyncio micropython module[s]" plus the required libraries?
                                      I C 2 Replies Last reply Reply Quote 0
                                      • I Offline
                                        iwahdan @soulsurfer
                                        @soulsurfer, using FTP or pymkr you can upload the uasyncio modules to your Pycom device with the following hierarchy :
                                        • uasyncio sub-modules into /flash/lib/uasyncio
                                        • websocket.server sub-module under: /flash/lib/uasyncio/websocket
                                        • collections sub-modules into /flash/lib/collections
                                        • logging sub-module into /flash/lib
                                        And then you can import uasyncio library into your script and start using it
                                        Wahdan
                                        S S 2 Replies Last reply Reply Quote 1
                                          Sympatron @iwahdan
                                          @iwahdan I think it would be nice to have this as frozen modules by default in the future.
                                            cmisztur @soulsurfer
                                            @soulsurfer here, I documented the process https://medium.com/@chrismisztur/pycom-uasyncio-installation-94931fc71283
                                            1 Reply Last reply Reply Quote 5
                                            • 1
                                            • 2
                                            • 2 / 2
