    Code run _thread.start_new_thread, that includes AWS MQTT causes guru meditation
    threadmqttaws
    2 Posts 2 Posters 799 Views 2 Watching
      timh
      Hi
      I have FiPy/GPY running with LTE-CAT-M1 or Wifi connections for a while.
      I wanted to look at including pybytes.
      However I find that if I run my code inside a new thread. _thread.start_new_thread
      LTE and WLAN can be setup in this thread, however as soon as I try to create an MQTT connection using the underlying AWS library I get a guru meditation error.
      Connected <WLAN>
      WDT enabled
      Connecting to mqtt
      Guru Meditation Error: Core  0 panic'ed (LoadProhibited)
      . Exception was unhandled.
      Register dump:
      PC      : 0x4008aa9d  PS      : 0x00060033  A0      : 0x4008c117  A1      : 0x3ffd54f0
      A2      : 0x3ffc513c  A3      : 0x00050023  A4      : 0x3ffc4fb4  A5      : 0x00000000
      A6      : 0x00000000  A7      : 0x00000000  A8      : 0x00000002  A9      : 0x3ffc4fac
      A10     : 0x00000000  A11     : 0x00000001  A12     : 0x3ffb7cdc  A13     : 0x00000000
      A14     : 0x00000005  A15     : 0x7fffffff  SAR     : 0x0000001f  EXCCAUSE: 0x0000001c
      EXCVADDR: 0x0000000c  LBEG    : 0x400e67e4  LEND    : 0x400e6820  LCOUNT  : 0x00000000
      Backtrace: 0x4008aa9d:0x3ffd54f0 0x4008c114:0x3ffd5520 0x4008c0ca:0x3ffc5ca0
      The AWS mqtt library creates it's own threads to handle connection and inbound messages.
      Not sure if this is a restriction of the platform or my approach.
      Tim
        james
        I have the same problem using this library or simple mqtt in another thread with version (1.18/1.19 Pybytes)
        rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
        configsip: 0, SPIWP:0xee
        mode:DIO, clock div:1
        load:0x3fff8028,len:8
        load:0x3fff8030,len:1984
        load:0x4009fa00,len:0
        load:0x4009fa00,len:19112
        entry 0x400a05e4
        Initializing filesystem as FatFS!
        Guru Meditation Error: Core  0 panic'ed (Cache disabled but cached memory region accessed)
        Core 0 register dump:
        PC      : 0x401f27e8  PS      : 0x00060c34  A0      : 0x8005582c  A1      : 0x3ffc0970
        A2      : 0x00000000  A3      : 0x00000001  A4      : 0x800995d1  A5      : 0x3ffea5f0
        A6      : 0x0000b030  A7      : 0x3ffea6a4  A8      : 0x8008cc86  A9      : 0x01000000
        A10     : 0x07040000  A11     : 0x00000000  A12     : 0x00000013  A13     : 0x00000000
        A14     : 0x3ffae270  A15     : 0x00000000  SAR     : 0x0000000e  EXCCAUSE: 0x00000007
        EXCVADDR: 0x00000000  LBEG    : 0x40099276  LEND    : 0x40099285  LCOUNT  : 0x00000000
        Core 0 was running in ISR context:
        EPC1    : 0x40092e5f  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x401f27e8
        with the old version (1.17.3.b1 or 1.18.0) the error was different but there was.
        Connecting to MQTT broker....
        ***ERROR*** A stack overflow in task MPThread has been detected.
        abort() was called at PC 0x4008e66c on core 1
        the mqtt library is:
        https://github.com/yutter/micropython-mqtt
        Furthermore
        after updating to the 1.18.0 or 1.19.4.b4 to try to understand if the problem related to the threads and mqtt had been solved I had another problem, I can not load some files ...
        example of what happens that did not happen before; I added the size of the files in which I have problems
        Reading file status
        Failed to read project status, uploading all files
        Creating dir lib
        Creating dir www
        Creating dir www/bootstrap
        Creating dir www/bootstrap/css
        Creating dir www/bootstrap/fonts
        Creating dir www/bootstrap/js
        Creating dir www/js
        [1/18] Writing file SI7006A20.py
        [2/18] Writing file boot.py
        [3/18] Writing file hal.py
        [4/18] Writing file lib/mqttserver.pub.pem
        [5/18] Writing file main.py
        [6/18] Writing file mqtt.py
        [7/18] Writing file umqtt.py
        [8/18] Writing file www/bootstrap/css/bootstrap.min.css  "filesize (121.3kb)"
        Failed to write file, trying again...
        Filecheck failed
        [9/18] Writing file www/bootstrap/js/bootstrap.min.js "filesize (36.9kb)"
        [10/18] Writing file www/index.html
        [11/18] Writing file www/js/angular.min.js "filesize (99.0kb)"
        Filecheck failed
        [12/18] Writing file www/js/app.js
        [13/18] Writing file www/js/jquery-1.11.1.js "filesize (282.8kb)"
        Filecheck failed
        [14/18] Writing file xApp.py
        [15/18] Writing file xConfigureFile.py
        [16/18] Writing file xHTTPConfigure.py
        [17/18] Writing file xWebServer.py
        [18/18] Writing file xWebSocket.py
        why?
        waiting for a quick reply
        best regards
        Giacomo
