    problems updating sqns firmware
    fipy firmwarelte nb iot
    4 Posts 2 Posters 947 Views 2 Watching
    • E Offline
      Eric Waai
      i'm trying to get the newest firmware on the LTE modem of the fipy
      but when i do this : sqnsupgrade.run('/sd/FIPY_NB1_37781.dup')
      i get :
        File "/flash/lib/sqnsupgrade.py", line 106, in run
      OSError: [Errno 2] ENOENT
      this is the firmware running on the fipy
      Pycom MicroPython 1.18.0 [v1.8.6-849-046b350] on 2018-06-01; FiPy with ESP32
      i downloaded the updated versions of the pycom libraries today.
      i tried formatting the SD card but that doesn't help
      any thoughts?
        timh @Eric Waai
        @eric-waai just checking, did you mount the SD device ?
        • E Offline
          Eric Waai
          yes i did
          the new sqnsupgrade.py file does that too by the way on line 87 so i figure it isn't needed to do that.
          also tried with mounting doesn't make a difference
          • E Offline
            Eric Waai
            getting further on this problem
            found list of OSErrors ENOENT means No such file or directory
            there was a typo in the file path
            at this point i'm getting other errors at line 121
            >>> sqnsupgrade.run('/sd/FIPY_GPY_NB1_37781.dup',921600)
            <<< Welcome to the SQN3330 firmware updater >>>
            Entering recovery mode
              File "/flash/lib/sqnsupgrade.py", line 121, in run
            TypeError: extra keyword arguments given
            reading the sqnsupgrade.py says that the line does
            print('Resetting.', end='', flush=True)
            guessing it is not important that to print something i removed the line
            running the upgrade again gives me this
              File "/flash/lib/sqnsupgrade.py", line 123, in run
              File "/flash/lib/sqnsupgrade.py", line 74, in wait_for_modem
            reading the code at that line 74 gives
            print('.', end='', flush=True)
            this makes me think that there is something wrong with the call of the print() function
            so i removed the
            flush=True
            from both lines. after running the sqnsupgrade i now get the following
            Resetting..
            Starting STP (DO NOT DISCONNECT POWER!!!)
            STP started
            Session opened: version 1, max transfer 8192 bytes
            Code download failed, aborting!
            this is how far i am at he moment still looking in to this
            any help is appreciated
            edit:
            after some more trying got some more info
            if i try the update again i get this error
            AT+SMSWBOOT=3,0 response b''
              File "/flash/lib/sqnsupgrade.py", line 131, in run
            OSError: AT+SMSWBOOT=3,0 failed!
            the modem is not responsive to any AT commands
            if i send just AT+CGMI i get ERROR
            i tried to locate the cause of the error of the code download
            i eddited the sqnsupgrade.py to find out where this error is generated
            it is in line 155
            except:
                    blob.close()
                    print('Code download failed 2, aborting!')
                    abort = True
            i'm really out of ideas for the moment
