    How to make sense of gps data sent to sigfox
    gpssipylopysigfox
    4 Posts 2 Posters 1.2k Views 2 Watching
      james.matthews
      Hi all,
      I'm trying to send latitude and longitude from the Pytrack to sigfox. The code I am using to do this is this:
      print(str(latitude), ":", str(longitude))
      s.send(struct.pack('f',float(latitude)) + struct.pack('f',float(longitude)))
      The print command gives me this:
      51.753743 : -1.252524
      but in Sigfox I see this:
      d5034f42b552a0bf
      ASCII: ..OB.R...
      You can see this in the attached image
      I've also tried this:
      s.send(str(latitude), ':',str(longitude))
      but it wasn't helpful. Can anyone help make this text something useful?
      Eventually I'd like to be able to automatically view this on a map. Could anyone help with that? would AWS be helpful here?
      • E Offline
        Eric73
        lat=b'\xd5\x03\x4f\x42
        struct.unpack('f',lat)
        (51.75374221801758,)
        lon=b'\xb5\x52\xa0\xbf'
        struct.unpack('f',lon)
        (-1.2525240182876587,)
        It's seem your sensor will to be near oxford isn't it ?
        https://www.google.fr/maps/place/51°45'13.5"N+1°15'09.1"W/@51.7539049,-1.254124,17.42z/data=!4m5!3m4!1s0x0:0x0!8m2!3d51.7537422!4d-1.252524
          james.matthews @Eric73
          @eric73 said in How to make sense of gps data sent to sigfox:
          That's awesome, thanks!
          However, I do not understand what you did. How (and why) did you know to write it like this:
          Thanks,
          • E Offline
            Eric73 @james.matthews
            @james-matthews struct.unpack work with "byte" objet. As we have to unpack a float this "byte" object must have a size of 4 bytes. [https://docs.python.org/2/library/struct.html]
            This float , have been packed in a binary form
            '''s.send(struct.pack('f',float(latitude)) + struct.pack('f',float(longitude)))'''
            then sent to sigfox backend data and showed in hexadecimal
            '''d5034f42b552a0bf'''
            so, to have original value you just have to unpack it from hexadecimal to float
            ''' lat=b'\xd5\x03\x4f\x42' '''this is the way to create and assign hexadecimal value to a 'python byte object' with len=4
