    FiPy Wi-Fi Node-to-Node Socket Error (OSError: -1)
    socket connectwififipy
    4 Posts 2 Posters 936 Views 2 Watching
      Joseph
      Hello!
      Apologies if someone has already posted this issue (or a similar one).
      I'm attempting to connect two FiPy's directly (no router) through Wi-Fi with one of the Fipy's as the client, and the other as the access point. I've managed to get the client to connect to the access point. However, when I try to create a socket on the client side, I get OSError: -1.
      Potential issues (based on Python documentation) and attempted solutions:
      1. Memory issues. Updated the firmware to 1.17.5.b6.
      2. Socket connection issues. Double checked IP and socket connection parameters. Please see below for the client code.
      # This file is prototype source code for Wi-Fi master that establishes
      # uni-directional communication (Master -> Slave) with Wi-Fi slave.
      from network import WLAN
      networkFound = Falseo
      netSSID = None
      pycom.rgbled(0xff3333) # red
      print("Starting MASTER up!")
      wlan = WLAN()
      wlan.init(mode=WLAN.STA_AP, ssid="FiPy1_WiFi", auth=(WLAN.WPA2,"fipy1wifiprototype"), channel=11, antenna=WLAN.EXT_ANT)
      # wlan.init(mode=WLAN.STA)
      # network_found = False
      while networkFound is False:
          print("Commencing scan!")
          nets = wlan.scan()
          print(nets)
          time.sleep(5)
          for net in nets:
              # Connect to Wi-Fi slave access point
              if net.ssid == "FiPy2_WiFi":
                  # network_found = True
                  print(net.ssid)
                  networkFound = True
                  wlan.connect(net.ssid, auth=(net.sec, "fipy2wifiprototype"), timeout=5000)
                  netSSID = net.ssid
                  pycom.rgbled(0x33ff33) # green
                  # wlan.ifconfig(id=0)
                  time.sleep(10)
                  print(wlan.isconnected())
                  break
                  print("NOT CONNECTED!")
      # print (wlan.ifconfig())
      try:
          s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
          pycom.rgbled(1000) # blue
          print ("Socket successfully created!")
      except socket.error as err:
          print ("Socket failed to be created with error %s" %err)
      print(netSSID)
      time.sleep(2)
      time.sleep(2)
      # port = 12345
      # host_ip = '192.168.4.1'
      print(socket.getaddrinfo("192.168.4.1", 80))
      time.sleep(2)
      print(socket.getaddrinfo("192.168.4.1", 80)[0][-1])
      time.sleep(2)
      s.connect(socket.getaddrinfo("192.168.4.1", 80)[0][-1])
      pycom.rgbled(0xffbb33) # orange
      time.sleep(2)
      print("The socket has successfully connected to your boy on port = %s" %(host_ip))
      dataString = "Sent from FiPy1"
      dataBytes = bytes(dataString, "utf-8")
      # Send data as quickly as possible
      for iteration in range(10):
          s.sendto(dataBytes, host_ip)
          pycom.rgbled(0x33ffdd) # green/blue hybrid
          print("Sent Data!")
      print("End of program!")
      # inputs = s.recv(1024)
      # barray = binascii.hexlify(inputs)
      # barray=barray.decode('utf-8')
      # color = hex(int(barray,16) + int ("0x00",16))
      # color = int(color)
      # pycom.rgbled(color)
      For reference, below is the access point code.
      # This file is prototype source code for Wi-Fi slave that establishes
      # uni-directional communication (Master -> Slave) with Wi-Fi master.
      print("Starting SLAVE up!")
      conn = None
      # Configure access point
      wlan = WLAN()
      wlan.init(mode=WLAN.AP, ssid="FiPy2_WiFi", auth=(WLAN.WPA2, 'fipy2wifiprototype'), channel=11, antenna=WLAN.EXT_ANT)
      time.sleep(10)
      wlan.ifconfig(id=1)
      time.sleep(10)
      try:
          print ("socket failed to be created with error %s" %err)
      port = 12345
      host_ip = ''
      s.bind((host_ip,port))
      s.listen()
      print("Listening for connection requests!")
      # Keep looping until connected.`
      # 1. One socket for listening for connection requests.
      # 2. One socket for actually receiving and sending data to client.
      while conn is None:
          print("Reached!")
          conn, addr = s.accept()
      # Receive data from socket buffer
          data = conn.recv(256)
          data = data.decode("utf-8")
          print(data)
      I'm somewhat baffled as I have been able to successfully connect to a router and create a socket on the client side.
      Any insights or suggestions would be greatly appreciated.
      Thank you!
      • danD Offline
        dan
        Hi @Joseph,
        I'm looking into it, it indeed doesn't work. I was able to get a more "descriptive" error OSError: [Errno 104] ECONNRESET by adding try-except to s.connect(...). I'll get back to you when I have more info.
          Joseph @dan
          Hi @dan,
          Were you able to find anything more about the issue?
          And if I may, could I ask you to test the on a pair of LoPy's? If the code works on the LoPy's, we'll probably purchase several LoPy's.
          Thanks!
          danD 1 Reply Last reply Reply Quote 0
          • danD Offline
            dan @Joseph
            Hi @joseph,
            No, not yet. I have spent a few days on it, but no progress. I keep getting Connection refused when trying to connect, so something must be wrong with my server code. Have you tried connecting it to a different device (e.g your computer)?
