    no execution after lora thread
    loramqttthreading
    5 Posts 3 Posters 846 Views 3 Watching
      james
      after
      _thread.start_new_thread(self.lora_loop(),())
      no code execution, in another thread mqtt error!!!!!
      class LoraGateway:
          def __init__(self, fileconfig=None):
              self.lastattrsend = 0
              self.config = fileconfig if fileconfig != None else XConfigureFile()
              self.deviceid = binascii.hexlify(unique_id())
              self.device = []
              self.devicedata = []
              self.wlan = WLAN(mode=WLAN.STA)
              self.rtc = RTC()
              self.mqttc = MQTTClient(b'TRK'+binascii.hexlify(unique_id()), "io.trackr.it", port=8883, user=self.config.file['accesstoken'], password=self.config.file['accesstoken'], ssl=True, ssl_params={'ca_certs':'lib/mqttserver.pub.pem'})
              self.mqttclient = MQTTClient(server="io.trackr.it", port=8883, ssl=True, ssl_params={'ca_certs':'lib/mqttserver.pub.pem'})
              self.mqttclient.set_connected_callback(self.con_cb)
              self.mqttclient.set_puback_callback(self.puback_cb)
              self.mqttclient.set_suback_callback(self.suback_cb)
              self.mqttclient.set_message_callback(self.msg_cb)
          def lora_loop(self):
              #while not (self.wlan.isconnected() and self.rtc.synced()):
              #    time.sleep(5)
              self.counter = LoraCounter(int(self.config.file['cytime']))
              print("Counter started")
              self.lora = LoRa(mode=LoRa.LORA, rx_iq=True)
              self.sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
              self.sock.setblocking(self.config.file['blockmode'])
              print("Lora started")
                  try:
                      recv_pkg = self.sock.recv(512)
                      if (len(recv_pkg) > 24):
                          print(recv_pkg)
                          recv_pkg_len = recv_pkg[25]
                          # XXXXXXXXXXXX=mac + B=Command + B=pkgsize + %ds=package
                          device_id, gateway_id, command, pkg_len, msg = struct.unpack(_LORA_PKG_FORMAT % recv_pkg_len, recv_pkg)
                          if (gateway_id==self.deviceid) or (gateway_id==b'000000000000' and command==_LORA_CMD_JOIN):
                              try:
                                  devidx = self.device.index(device_id)
                              except Exception as e:
                                  self.device.append(device_id)
                              if (command == _LORA_CMD_JOIN):
                                  ack_pkg = struct.pack(_LORA_PKG_ACK_JOINED, device_id, devidx, 200, self.deviceid)
                              elif (command == _LORA_CMD_SEND):
                                  if self.rtc.synced:
                                      ack_pkg = struct.pack(_LORA_PKG_ACK_FORMAT, device_id, devidx, 200, self.counter.seconds, self.counter.epsleeptime )
                                      ## get data from struct
                                      array_s = (msg.decode('ascii')).split(';')
                                      temp = float(array_s[0])
                                      humy = float(array_s[1])
                                      volt = float(array_s[2])
                                      ## make object an push in collection
                                      self.devicedata.append(LoroData(device=device_id, temperature=temp, humidity=humy, voltage=volt))
                                      ack_pkg = struct.pack(_LORA_PKG_ACK_FORMAT, device_id, devidx, 200, 120, self.counter.epsleeptime )
                              sendack = True
                              if (self.wlan.isconnected() and self.rtc.synced()):
                                  try:
                                      self.mqttc.connect()
                                      if (self.lastattrsend != self.counter.ms_time):
                                          self.mqttc.publish('v1/devices/me/attributes', _MQTT_GATWY_ATTRIBUTE_PKG_FORMAT % (LocalTimeToStrFormat(),str(self.deviceid,'utf-8'),self.config.file['cytime']))
                                          self.lastattrsend = self.counter.ms_time
                                          self.mqttc.publish('v1/gateway/connect', _MQTT_DEVICE_PKG_FORMAT % (str(device_id,'utf-8')))
                                          self.mqttc.publish('v1/gateway/attributes', _MQTT_SONDA_ATTRIBUTE_PKG_FORMAT % (str(device_id,'utf-8'),LocalTimeToStrFormat(),str(device_id,'utf-8'),str(self.deviceid,'utf-8')))
                                          self.mqttc.publish('v1/gateway/telemetry', _MQTT_TELEMETRY_PKG_FORMAT % (str(device_id,'utf-8'),self.counter.ms_time,temp,humy,volt))
                                      self.mqttc.disconnect()
                                      sendack = False
                                      print('MQTT Exception:')
                                      print(e)
                              #send device ack join or package
                              print(ack_pkg)
                              self.sock.send(ack_pkg)
                              print('ACK SEND')
                      gc.collect() # enable garbage collector
                      print('LoRa loop Exception:')
                      print(e)
          def thread_connect(self):
              BlinkingStart(250)
              # WLAN CONFIGURE
              print("Start WLAN...")
              if self.config.file['wlan']['dhcp'] != True:
                  self.wlan.ifconfig(config=(self.config.file['wlan']['ipaddress'], self.config.file['wlan']['subnet'], self.config.file['wlan']['gateway'],  self.config.file['wlan']['dns']))
              keytype = WLAN.WPA2
              if self.config.file['wlan']['authtype']=='WEB':
                  keytype = WLAN.WEB
              elif self.config.file['wlan']['authtype']=='WPA':
                  keytype = WLAN.WPA
              elif self.config.file['wlan']['authtype']=='WPA2':
                  keytype = WLAN.WPA2
                  if not self.wlan.isconnected():
                      try:
                          print(self.config.file['wlan']['ssid'])
                          print(keytype)
                          print(self.config.file['wlan']['password'])
                          print(self.config.file['wlan']['dhcp'])
                          # WLAN CONNECT
                          self.wlan.connect(self.config.file['wlan']['ssid'], auth=(keytype, self.config.file['wlan']['password']))
                          while not self.wlan.isconnected():
                              time.sleep_ms(50)
                          print("WLAN Connected")
                          print(self.wlan.ifconfig())
                          # RTC CONFIGURE
                          ntps = self.config.file['ntpserver']
                          print(ntps)
                          if (ntps == ""):
                              ntps = "0.it.pool.ntp.org"
                          self.rtc.ntp_sync(ntps, 3600)
                          while not self.rtc.synced():
                              time.sleep_ms(50)
                          print("RTC Syncronized")
                          print(self.rtc.now())
                          self.counter.timeupdate()
                          BlinkingStop()
                          LED('P20',False).On()
                          #_thread.start_new_thread(self.thread_mqtt(),())
                          print(e)
                      time.sleep(60)
          ### mqtt callback begin
          def puback_cb(self, msg_id):
              print('PUBACK ID = %r' % msg_id)
          def suback_cb(self, msg_id, qos):
              print('SUBACK ID = %r, Accepted QOS = %r' % (msg_id, qos))
          def con_cb(self, connected):
              if connected:
                  pass
                  #client.subscribe('subscribe/topic')
          def msg_cb(self, topic, pay):
              print('Received %s: %s' % (topic.decode("utf-8"), pay.decode("utf-8")))
          ### mqtt callback end
          def thread_mqtt(self):
              print("MQTT loop connect")
              #mqttc = MQTTClient(b'TRK'+binascii.hexlify(unique_id()), server="io.trackr.it", port=8883,user=self.config.file['accesstoken'], password=self.config.file['accesstoken'])
              #mqttc.connect(ssl=True, ca_certs='lib/mqttserver.pub.pem')
              #mqttc = MQTTClient(b'TRK'+binascii.hexlify(unique_id()), "io.trackr.it", port=8883, user=self.config.file['accesstoken'], password=self.config.file['accesstoken'], ssl=True, ssl_params={'ca_certs':'lib/mqttserver.pub.pem'})
              #mqttc.connect()
              print("MQTT loop start")
              while self.wlan.isconnected():
                  time.sleep(60)
              self.mqttclient.connect(client_id=b'TRK'+binascii.hexlify(unique_id()), user=self.config.file['accesstoken'], password=self.config.file['accesstoken'] )
                  if self.mqttclient.isconnected():
                      while (len(self.devicedata)>0):
                          data = self.devicedata.pop(0)
                          self.mqttclient.publish(topic='v1/gateway/connect', payload=_MQTT_DEVICE_PKG_FORMAT % (str(data.Device,'utf-8')))
                          self.mqttclient.publish(topic='v1/gateway/attributes', payload=_MQTT_SONDA_ATTRIBUTE_PKG_FORMAT % (str(data.Device,'utf-8'),LocalTimeToStrFormat(),str(data.Device,'utf-8'),str(self.deviceid,'utf-8')))
                          self.mqttclient.publish(topic='v1/gateway/telemetry', payload=_MQTT_TELEMETRY_PKG_FORMAT % (str(data.Device,'utf-8'),self. counter.ms_time,data.Temperature, data.Humidity, data.Voltage))
          def start(self):
              _thread.start_new_thread(self.thread_connect,())
              print('start loop')
                  if self.wlan.isconnected():
                      try:
                          print('mqtt connect')
                          print('mqtt publish')
                          time.sleep(60)
                      except:
                          continue
        cdjambov
        I am having the same problem with my lopy/pytrack combo. I have two methods - one to handle lora comms and one to get gps coords. Both methods work ok if used as separate projects(separate main.py file executed after boot.py).
        The second thread is never executed. The print statements also never gets executed.
        lora_thread_id = _thread.start_new_thread(loraSendReceive(), None)
        gps_thread_id = _thread.start_new_thread(get_gps_coords(), None)
        print (lora_thread_id)
        print (gps_thread_id)
          cdjambov @cdjambov
          @cdjambov said in no execution after lora thread:
          I have swapped the threads start lines as per above and the lora thread did not execute this time.
            robert-hh @james
            @james You could try to insert a short utime.sleep() call. Busy while True loops tend to absorb all CPU time.
              cdjambov @robert-hh
              @robert-hh Hello there Robert. Thanks for the reply. Both of my threads have 60 sec sleeps inside. The lora thread have other sleeps as well.
