    Has anyone successfully used lora.nvram_save() and restore?
    lopylopy lorawanlorawan otaalopy loralopy4
    3 Posts 2 Posters 675 Views 2 Watching
    • H Offline
      Harish kumar
      Hi Everyone !
      I am confused with using lora.nvram_save and restore. I am using in my program but I am not sure where and how to use. Can someone guide me in this. I will put my code here.
      Thank you in Advance.
      from network import LoRa
      import ubinascii
      store =["26012FF8", "26012FF7", "f82f0126" ]
      #creating a OTAA connection
      app_eui = ubinascii.unhexlify('0004A30B00000000')
      app_key = ubinascii.unhexlify('DE71C5CA71E05F92FE3B000000000')
      Join a network with OTAA
      #wait until the module to join
      while not lora.has_joined():
      time.sleep(2.5)
      print('Not yet joined...')
      #create a lora socket
      #set lorawan datarate
      #make the socket blocking
      s.setblocking(True)
      time.sleep(3000)
      s.send(bytes([0x01, 0x02, 0x03]))
      time.sleep(3000)
      lora.nvram_save()
      lora = LoRa(mode=LoRa.LORA, region=LoRa.EU868, sf = 7, frequency = 868500000)
      # create a raw LoRa socket
      s.setblocking(True)
      rx_data = s.recv(64)
      dev_addr = rx_data[1:5]
      print("Dev-Addr: ", binascii.hexlify(dev_addr))
      x = 0
      for x in range(0, 3):
          if(binascii.unhexlify(store[x]) == dev_addr):
              print('OK')
              # get any data received...
              #rx_data = s.recv(64)
              print(rx_data)
              # sending data to server with sf = 12
              lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868,  sf = 12)
              # send some data
              s.send(rx_data)
              print('data sent')
              print('Not OK')
      lora.nvram_restore()
      #join a network using OTAA
      #doing uplink
      #doing downlink
      data = s.recv(64)
      first4 = data[0:4]
      store.append(first4)
      second4 = data[5:9]
      store.append(second4)
      print(data)
      And here, I am trying to save my OTAA connection and at last I am restoring those keys to do uplink again to get some downlinks.
        jcaron @Harish kumar
        @harish-kumar you only need to use nvram_save/restore if you use deep sleep (or cut power to the LoPy), which is not the case here.
        Just keep the same Lora object and socket and don’t join again...
        • H Offline
          Harish kumar @jcaron
          @jcaron oh thank you. I will do that. And I need a small help from you. In this code, I am trying to start my downlink once in a day. So I am using this code.
          a = time.localtime()
          hour = a.tm_hour
          minutes = a.tm_min
          if hour == 10 and minutes == 40:
          print('{0}:{1}'.format(hour, minutes))
          But it's not working properly. Do I have to change some conditions ?
