    FiPy connects COM forever and
    fipyproblemcom port
    6 Posts 3 Posters 996 Views 3 Watching
      szyba91
      Hello every one,
      A week ago I've started to work with my FiPy module with Extension Board 2.0 and this is also my first time with ESP32.
      During this week everythink was fine. I've been making tutorials one by one form https://docs.pycom.io/chapter/gettingstarted/registration/lora.html
      Just yesterday I've faces with frist problem with "Not safe booting, disabled in settings", I've stack for a moment i couldn't upload any code to my FiPy but I was able to fix this problem without doing nothing actually :)
      Just today i faced with another problem. In both IDEs Atom and VS Code I have the same problem. Its stack during connecting - result :
      Connecting port COM5... and I can't reach arrows >>>
      What is interesting I'm able to upload code to FiPy from project using "Upload" button. Here is the resoult :
      Connecting on COM5...
      Uploading project (main folder)...
      Reading file status
      [1/1] Writing file main.py
      OKets Jun 8 2016 00:22:57
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:1728
      load:0x4009fa00,len:0
      load:0x4009fa00,len:14584
      entry 0x400a059c
      Pybytes library: v0.9.0
      File "main.py", line 9
      SyntaxError: invalid syntax
      Pycom MicroPython 1.18.0.r1 [v1.8.6-849-9569a73] on 2018-07-20; FiPy with ESP32
      Code has been load to board beacuse I can see blinking RGB diode with diferent colours (just for testing)
      And there I can see the arrows at the bottom but I can write any commends here.
      Information bout firmwere versions, IDE etc:
      I have two FiPys module with extension bords 2.0
      FiPys firmware version1.18.0.r1
      Visual Studio version 1.25.1
      Atom version: 1.29.0
      Pymakrs version 1.0.1
      Jumpers : RTS and CTS are removed, rest of them is on its place
      Windows 10 64bit
      Ps.
      During wrting this I've reach arrows >>> at terminal for the moment but it was temporary :(
      I will be very glad for help
      E robert-hhR 2 Replies Last reply Reply Quote 0
      • E Offline
        egimbernat @szyba91
        @szyba91 at first glance, your code is causing an error, this could lead to REPL power off, since technically your code is crashing.
        You may also check for any other source that is using that port (COM5), for example many Atom windows and Pycom updater.
          robert-hh @szyba91
          @szyba91 You could try a safe boot, either by pushing Ctrl-f of booting with p12 pulled high.
            szyba91 @robert-hh
            @robert-hh P12 schould be pulled to Vcc by resistor right ? Crrl-f should be pushed insted of "upload" ? (sorry for silly questions)
              szyba91 @egimbernat
              @egimbernat Right! Thanks - actually the currernt situation is in the "Exp Board 2.0 serial communication problem" in extension board tag. And it seams that it is not realted to code bugs :/
                robert-hh @szyba91
                @szyba91 P12 can be pulled up directly. But using a resistor is also OK. 4.7K is a good choice.
                CTRL-F is to be pushed in the Terminal window, where you expect the REPL prompt. it will be caught the the serial interrupt handler.
