NameError: name '' is not defined when upload the "Lopy to Lopy" example
I can run the "Lopy to Lopy" example code from Atom on my FiPy, but when I do the upload from Atom I get the "NameError: name '' is not defined" error on line 4. Line 4 is a blank line in the example. Looking for some help please.
Uploading project (main folder)...
Not safe booting, disabled in settings
Reading file status
[1/3] Writing file boot.py
[2/3] Writing file main.py
[3/3] Writing file mymain.py
OKets Jun 8 2016 00:22:57rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff8028,len:8
load:0x3fff8030,len:1728
load:0x4009fa00,len:0
load:0x4009fa00,len:14584
entry 0x400a059c
File "main.py", line 4, in <module>
Pycom MicroPython 1.18.1.r1 [v1.8.6-849-b0520f1] on 2018-08-29; FiPy with ESP32 -
I think I found the problem. For some reason there were extra unprinted characters added to the blank lines when doing the copy-paste from the example documentation.
Hi @grideagle,
Thank you for reporting that, I've reported it to GitBook. The current workaround is to use the "copy" button it the top right corner of the code section.
