    Pymakr in Docker
    2 Posts 1 Posters 1.1k Views 1 Watching
      jasonriedy
      For anyone having issues with the pymakr prerequisites, a Docker container appears to be helpful. My Dockerfile is appended, although I only have it working for "locally attached" devices. The pymakr deb you want to use should be in the debdir/ subdirectory. I'm still trying to figure out forwarding that will let the Docker-based pymakr reach a remotely connected LoPy. SSH SOCKS forwarding works for remotely network connected devices given pymakr running directly and not in a container, but forwarding from within a container is more complicated.
      (Ok, it appears "file upload" doesn't work. Just pasting, so no idea how it'll be formatted.)
      FROM debian:jessie
      RUN apt-get update && apt-get install -y pyqt4-dev-tools python-qscintilla2 git sudo python-qt4-sql firefox-esr python-pygments python-chardet python-serial
      COPY debdir /debdir
      RUN sh -c 'dpkg -i /debdir/*.deb'
      Apparently, the uid and gid must match the running user... Have not tested.
      RUN export uid=1000 gid=1000 &&
      mkdir -p /home/developer &&
      echo "developer:x:${uid}:${gid}:Developer,,,:/home/developer:/bin/bash" >> /etc/passwd &&
      echo "developer:x:${uid}:" >> /etc/group &&
      echo "developer ALL=(ALL) NOPASSWD: ALL" > /etc/sudoers.d/developer &&
      chmod 0440 /etc/sudoers.d/developer &&
      chown ${uid}:${gid} -R /home/developer
      USER developer
      ENV HOME /home/developer
      #RUN cd /home/developer && git clone https://github.com/pycom/Pymakr && cd Pymakr && sudo python install.py -- nope, see their kitchen repo
      CMD /usr/bin/pymakr
      Assuming the container is named pymakr, use the following to run:
      docker run -ti --rm -e DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix -v $HOME/.Xauthority:/home/developer/.Xauthority --net=host --pid=host --ipc=host pymakr
      Add --device=/dev/ttyUSB0 for the serial port when already connected
        jasonriedy
        Ok, some of the bolded lines are prefixed by # for comments. ugh.
        And I have to wait three minutes because I'm a new user. Goodie.
