Updating code is not working!!!
I'm trying to upload code to the board using the Pycharm with Micropython plugin. The Expansion does not respond.
Connecting to COM7 Uploading files: 0% (0/1) C:\dev\source\personal\embedded\pycom\blink\boot.py -> boot.py b'Traceback (most recent call last):\r\n File "boot.py", line 12, in <module>\r\nKeyboardInterrupt: \r\nPybytes library: v0.9.0\r\nStarting UART...\r\n' Traceback (most recent call last): File "C:\Users\abc\.PyCharmCE2018.2\config\plugins\intellij-micropython/scripts/microupload.py", line 138, in <module> main(sys.argv[1:]) File "C:\Users\abc\.PyCharmCE2018.2\config\plugins\intellij-micropython/scripts/microupload.py", line 79, in main files.put(remote_path, fd.read()) File "C:\Users\abc\AppData\Local\Programs\Python\Python37-32\lib\site-packages\ampy\files.py", line 157, in put self._pyboard.enter_raw_repl() File "C:\Users\abc\AppData\Local\Programs\Python\Python37-32\lib\site-packages\ampy\pyboard.py", line 192, in enter_raw_repl raise PyboardError('could not enter raw repl') ampy.pyboard.PyboardError: could not enter raw repl
I have a demo to do with this stuff, please help.
@averri Besides that, I tried adafruit-ampy, which seems to be used by pycharm, and it works fine. Please be aware, that the files on the device mist be stored under /flash directory (or /sd, it mounted there). So a boot.py must have the target name /flash/boot.py
@averri Why don't you use ftp?
@dan I have done a factory reset (connecting G28 pin to the +3.3v). After that, I was able to upload the code again.
I had tried Pymakr with VisualStudio, it was not working fine. The Pymakr with Atom is working, but I prefer to use the Pycharm, the IDE is much better in many aspects.
@averri Hi, any reason you're not using Pymakr with Atom or VSCode?
