    GPy with Hologram SIM
    cat-m1gpy lte m1
    3 Posts 2 Posters 796 Views 3 Watching
      tlanier
      Ok, I'm back to try to see if things have gotten any better since my last tests.
      I've upgraded the GPy firmware and the modem firmware to the latest stable version.
      I'm trying to run the example CAT-M1 test program from the documentation. I added a few print statements to see what is happening. I have a Hologram SIM.
      It works the first time I run the program. It crashes if I run the program a second time.
      import ssl
      from network import LTE
      print('new LTE')
      lte = LTE()         # instantiate the LTE object
      print('attach')
      lte.attach()        # attach the cellular modem to a base station
      while not lte.isattached():
          print('attaching...')
          time.sleep(0.25)
      print('connect')
      lte.connect()       # start a data session and obtain an IP address
      while not lte.isconnected():
          print('connecting...')
          time.sleep(0.25)
      print('receiving data')
      s = socket.socket()
      s = ssl.wrap_socket(s)
      s.connect(socket.getaddrinfo('www.google.com', 443)[0][-1])
      s.send(b"GET / HTTP/1.0\r\n\r\n")
      print(s.recv(128))
      s.close()
      lte.disconnect()
      lte.dettach()
      Here's the error output on the second run:
      new LTE
      ╝Traceback (most recent call last):
        File "<stdin>", line 8, in <module>
      OSError: the requested operation failed
      Pycom MicroPython 1.18.1.r1 [v1.8.6-849-b0520f1] on 2018-08-29; GPy with ESP32
      Type "help()" for more information.```
        panda
        You are probably needing to detach and reset the modem at the beginning of your code in order to get stability. The modem runs independant of the processor so the state will survive a board or system reset.
        T 1 Reply Last reply Reply Quote 1
          tlanier @panda
          @panda
          I added an lte.reset() call at the start and now the program crashes on a blank line the second time it is run. Again it works fine the first time the program is run.
