    High current consumption in deep sleep: 80 mA
    gpydeep sleep
    8 Posts 5 Posters 1.2k Views 6 Watching
      averri
      Hi, I'm testing GPy on deep sleep mode, and the current consumption is around 80 mA. I was expecting something in the uA range, do you know what's wrong?
      I'm invoking the deep sleep with:
      machine.deepsleep(10000)
      I have a boot.py file with WiFi configuration. I'm using GPy v1.0.
        robert-hh @averri
        @averri You have to de-init the LTE modem.
          averri
          It does not work. I'm using the following code:
          import json
          from mqtt import MQTTClient
          from network import WLAN, LTE
          def sleep(millis):
              print('Going to sleep...')
              lte = LTE()
              lte.deinit()
              machine.deepsleep(millis)
          def handler(topic, data):
              print(topic, data)
              payload = json.loads(data.decode('utf-8'))
              msg = payload['msg'] if 'msg' in payload else None
              if msg == 'deepSleep':  # Here we enter deep sleep.
                  sleep(10000)
          def connect_mqtt():
              """Connects to the MQTT queue."""
              print('Connecting to the MQTT server...')
              c = MQTTClient('alex-device', 'xxx', port=1883, user='xxx', password='xxx')
              c.set_callback(handler)
              c.connect()
              c.publish('inTest', 'Device connected!')
              c.subscribe('outTest')
              return c
          def wait_for_wlan():
                  if WLAN().mode() == WLAN.STA:
                      break
                      time.sleep(0.5)
          def main():
              wait_for_wlan()
              c = connect_mqtt()
                  time.sleep(0.5)
                  # Check MQTT message.
                  c.check_msg()
          if __name__ == '__main__':
              main()
          The result:
          Going to sleep...
            File "main.py", line 112, in <module>
            File "main.py", line 95, in main
            File "mqtt.py", line 206, in check_msg
            File "mqtt.py", line 193, in wait_msg
            File "main.py", line 34, in handler
            File "main.py", line 15, in sleep
          OSError: the requested operation failed
          Pycom MicroPython 1.18.0.r1 [v1.8.6-849-9569a73] on 2018-07-20; GPy with ESP32
            averri
            @robert-hh The LTE deinit is not working, please see the message above.
              jcaron @averri
              @averri Do you have a SIM card in the module? IIRC LTE.deinit() won't work without one.
                averri @jcaron
                @jcaron No, I don't have a SIM card. Is it possible to disable the LTE without the SIM card?
                  serafimsaudade
                  I'm having the same problem. When I arrive at home a will insert a SIM card and check if the current consumption decrease.
                  Update:
                  I have insert a SIM card. And make lte.deinit() and de current consumption in deepsleep drop to 0.022 mA.
                    andreas @averri
                    @averri said in High current consumption in deep sleep: 80 mA:
                    We just mitigated this through [1] by invoking lte.deinit() with the "reset" operation like
                    lte.deinit(detach=False, reset=True)
                    [1] https://github.com/hiveeyes/hiveeyes-micropython-firmware/commit/ec7c80e1219fb119c2881a0019cecdfad220f29f
