    NB-IoT in Austria
    nb-iotfipyattach
    12 Posts 3 Posters 1.8k Views 4 Watching
      dommei
      i am trying to connect to NB-IoT in Austria. The APN data is from my provider A1. I would like to send some sensor data over NB-IoT to test it.
      when i try to attach it fails everytime.
      Do you have any advice for me how can I attach the modem and how could I send/receive data? I didn't find many documentation about that..
      Thank you.
      My Code:
      from network import LTE
      from SI7006A20 import SI7006A20
      # Disable WiFi
      from network import WLAN
      wlan = WLAN()
      wlan.init()
      # Disable Heartbeat
      pycom.rgbled(0x0)
      lte = LTE()
      lte.send_at_cmd('AT+CFUN=0') # disable modem
      lte.send_at_cmd('AT!="clearscanconfig"') # clear scanned frequencies
      lte.send_at_cmd('AT!="addscanfreq band=20 dl-earfcn=6300"') # set scanned frequency
      lte.send_at_cmd('AT+CGDCONT=1,"IP","try.a1.net"') # set APN (Access Point Name)
      lte.send_at_cmd('AT+COPS=?') # scan available networks
      lte.send_at_cmd('AT+CFUN=1') # enable modem
      while not lte.isattached():
          print("attaching...")
          pass
      lte.connect()
      while not lte.isconnected():
          print("connecting...")
          pass
      # now use socket as usual...```
        tuftec
        Hi Dom,
        Firstly, you need Band 8 support for Vodafone Australia. This is currently not supported in the existing FiPy firmware. There is an upgrade coming, but you might need to srnd your FiPy back to Pycom. See annocements elsewhere in the forum.
        Secondly, you need to contact Vadafone to obtain correct SIMs and access details.
        Good luck.
        Cheers.
        Peter.
          robert-hh @tuftec
          @tuftec Austria, not Australia!
          T 1 Reply Last reply Reply Quote 1
            tuftec @robert-hh
            @robert-hh ha ha!!!
            My bad.
            Cheers.
              robert-hh @tuftec
              @tuftec said in NB-IoT in Austria:
              @robert-hh ha ha!!!
              My bad.
              Cheers.
              There are quite a few jokes about that.
                dommei
                yes Austria not Australia...
                The APN data is from the provider and they said they activated NB-IoT in my area. The bad thing is that they didn't test it with pycom devices.. so thats the reason why i ask here for help :)
                  robert-hh @dommei
                  @dommei What is the result of:
                  lte.send_at_cmd('AT+CEREG?')
                  You may have to wait for a while, until the device attaches, and obviously you need a specific SIM for NB-IoT.
                  Edit: Looking at the press announcement, it is likely that they use Band 8 (900 MHz band). This is not supported by the Pycom devices yet. You have to send them back to Pycom for an fix. See this post: https://forum.pycom.io/topic/3843/important-news-regarding-cat-m1-and-nb-iot-cellular-range
                    dommei @robert-hh
                    @robert-hh The return value of AT+CEREG? is 2.4
                      robert-hh @dommei
                      @dommei 2,4 means:
                      2: scanning with unsolicited messages enabled
                      4: unknown (e.g. out of E-UTRAN coverage)
                      So: not attached
                        tuftec
                        If a lack of band 8 support, this is the same problem that I have with Vodafone Australia!
                        I am waiting for a response to my RMA request.
                        Peter.
                          dommei @robert-hh
                          @robert-hh
                          hey again, now i have
                          2,0 as return value
                          any advice now? thank you
                            robert-hh @dommei
                            @dommei That's means: "not registered, MT is not currently searching an operator to register to". At my device, it toggles between 2,0 and 2,2. The response you need is 2,1 or 2,5.
                            The AT command set document is here: https://firebasestorage.googleapis.com/v0/b/gitbook-28427.appspot.com/o/assets%2F-LIL0iGdl11z7Jos_jpX%2F-LKN7scqKKkb6TqB3uYO%2F-LKN866sBhZY7wCqpQPA%2Fmonarch_4g-ez_lr5110_atcommands_referencemanual_rev3_noconfidential.pdf?generation=1534782117167775&alt=media
                            With your input, this post could be even better šŸ’—
