    SI7021 I2C pin setup (SOLVED)
    micropythonsi7021i2c
    59 Posts 4 Posters 14.0k Views 4 Watching
      robert-hh @nespressif
      @nespressif The difference is in writing the command. In your example, you are writing a single int value,
      i2c.writeto(0x40, 0xf3) #read temp no hold
      wheras in the class it is two bytes, where the first byte contains the command, and the second a zero.
        def write_command(self, command_byte):
          self.cbuffer[0] = command_byte
          self.i2c.writeto(self.addr, self.cbuffer)
      Since you have a suitable device at hand, could you try to change the class accordingly. e.g. like below:
        def readTemp(self):
          self.i2c.writeto(self.addr, CMD_MEASURE_TEMPERATURE)
          sleep_ms(25)
          temp = self.i2c.readfrom(self.addr,3)
          temp2 = temp[0] << 8
          temp2 = temp2 | temp[1]
          return (175.72 * temp2 / 65536) - 46.85
      nespressifN 1 Reply Last reply Reply Quote 1
      • nespressifN Offline
        nespressif @robert-hh
        @robert-hh I'm sorry, but I don't understand what you want me to do. I've already tried creating a SI7021(i2c) class object and I get that error. Maybe that's how it works, I'll try it:
            #self.cbuffer[0] = command_byte
            self.i2c.writeto(self.addr, command_byte)
        robert-hhR 2 Replies Last reply Reply Quote 1
            @nespressif @tttadam I just verified that change to write_command(), and it works.
            Setting: Vin of the SI7021 module at 3.3V, not external pull-up resistors.
            T 1 Reply Last reply Reply Quote 1
              tttadam @robert-hh
              @robert-hh 1sorry for the delay.
              I took pictures of the sensors.
              https://photos.app.goo.gl/d1p1NSwZaXU41QbK8
                tttadam @robert-hh
                @robert-hh Sorry But it is not clear for me. What sould I change in SI7021.py file?
                Thnak you
                  robert-hh @tttadam
                  @tttadam The board looks fine. Not additional resistors required. In the SI7021 class there is a function call write_command. Change that function into:
                    tttadam @robert-hh
                    @robert-hh well I ran my little baudrate finder again with modflyed write_command method.
                    But I got tha same result, exept it frozed at 2964 baud.
                    I am not sure what am I missing.
                      robert-hh @tttadam
                      @tttadam Don't care about the baud rate. Here is works well at the default baud rate (I purchased I device for testing). This is the class code which works:
                      from time import sleep_ms
                      from machine import Pin, I2C
                      # Default Address
                      SI7021_I2C_DEFAULT_ADDR = 0x40
                      # Commands
                      CMD_MEASURE_RELATIVE_HUMIDITY_HOLD_MASTER_MODE = 0xE5
                      CMD_MEASURE_RELATIVE_HUMIDITY = 0xF5
                      CMD_MEASURE_TEMPERATURE_HOLD_MASTER_MODE = 0xE3
                      CMD_MEASURE_TEMPERATURE = 0xF3
                      CMD_READ_TEMPERATURE_VALUE_FROM_PREVIOUS_RH_MEASUREMENT = 0xE0
                      CMD_RESET = 0xFE
                      CMD_WRITE_RH_T_USER_REGISTER_1 = 0xE6
                      CMD_READ_RH_T_USER_REGISTER_1 = 0xE7
                      CMD_WRITE_HEATER_CONTROL_REGISTER = 0x51
                      CMD_READ_HEATER_CONTROL_REGISTER = 0x11
                      class SI7021(object):
                        def __init__(self, i2c=None):
                          self.i2c = i2c
                          self.addr = SI7021_I2C_DEFAULT_ADDR
                          self.cbuffer = bytearray(2)
                          self.cbuffer[1] = 0x00
                        def readTemp(self):
                          self.write_command(CMD_MEASURE_TEMPERATURE)
                          sleep_ms(25)
                        def readRH(self):
                          self.write_command(CMD_MEASURE_RELATIVE_HUMIDITY)
                          sleep_ms(25)
                          rh = self.i2c.readfrom(self.addr, 3)
                          rh2 = rh[0] << 8
                          rh2 = rh2 | rh[1]
                          return (125 * rh2 / 65536) - 6
                      It is called with:
                      from machine import I2C
                      i2c=I2C(0, I2C.MASTER)
                      from SI7021 import SI7021
                      m = SI7021(i2c)
                      print(m.readRH(), m.readTemp())
                      Device connected at P9 = SDA and P10 = SCL, Vin at 3.3V
                        tttadam @robert-hh
                        @robert-hh
                          File "main.py", line 6, in <module>
                          File "/flash/lib/SI7021.py", line 32, in readTemp
                        OSError: I2C bus error
                        still the same. If it's working on your side, than my sensor must be dead.
                          robert-hh @tttadam
                          @tttadam Please check that there is only one copy of SI7021.py installed on your device. When working with pymakr, that may happen. Please use simple tools like ftp for the check. And yes, the version I posted works. No, I do not think that your device is defect. And it is well protected. Ans since it responds well to scan(), the wiring is also fine. So the code or code set-up is most probably the problem.
                            tttadam @robert-hh
                            @robert-hh Can I do a factory reset somehow? Delete everything from the device.
                              robert-hh @tttadam
                              @tttadam When you update the firmware, then you have in the advanced section the option to erase the file system. Other method from the REPL prompt:
                              import uos
                              uos.mkfs("/flash")
                              And then reboot.
                                tttadam @robert-hh
                                @robert-hh Well I formatted the flash, then restarted the device.
                                Than uploded SI7021.py, an empyt boot file, and a main.py with 6 line of code. But still no luck...
                                Uploading project (main folder)...
                                Not safe booting, disabled in settings
                                Reading file status
                                Failed to read project status, uploading all files
                                Creating dir lib
                                [1/3] Writing file boot.py
                                [2/3] Writing file lib/SI7021.py
                                [3/3] Writing file main.py
                                OKets Jun  8 2016 00:22:57
                                rst:0x7 (TG0WDT_SYS_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
                                configsip: 0, SPIWP:0xee
                                mode:DIO, clock div:1
                                load:0x3fff8028,len:8
                                load:0x3fff8030,len:1728
                                load:0x4009fa00,len:0
                                load:0x4009fa00,len:14584
                                entry 0x400a059c
                                [64]
                                Pycom MicroPython 1.18.1.r1 [v1.8.6-849-b0520f1] on 2018-08-29; LoPy4 with ESP32
                                my main.py:
                                print(i2c.scan())
                                m = SI7021(i2c)
                                my boot.py, is just comment
                                and my SI7021 is like this:
                                # Default Address
                                # Commands
                                CMD_RESET = 0xFE
                                    self.i2c = i2c
                                  def readTemp(self):
                                    sleep_ms(25)
                                  def readRH(self):
                                    sleep_ms(25)
                                    rh2 = rh[0] << 8
                                    rh2 = rh2 | rh[1]
                                  robert-hh @tttadam
                                  @tttadam It is interesting that readRH() seemed to have worked, since the code fails at readTemp(). Try two things:
                                  a) use only readRH
                                  b) increase the sleep_ms(25) to sleep_ms(50).
                                    tttadam @robert-hh
                                    @robert-hh
                                    YAAAAAY!!! :D
                                    Increasing the sleep_ms to 50 solved it!
                                    [64]
                                    42.83194 26.78852
                                      robert-hh @tttadam
                                      @tttadam That's very good. When trying to read before the conversion is done you get an I2C bus error. The strange thing is, that according to the data sheet 25ms is already a safe value. The maximum conversion time according to the data sheet is 12 ms for RH at 12 bit resolution.
                                      I found no robust way to scan the device for a "conversion ready" state.
                                        robert-hh @tttadam
                                        @tttadam I extended the class SI7021 a little bit. It also waits now for max 100ms time for the device to return a value, but returns earlier if values are returned. A documentation is added too.
                                        https://github.com/robert-hh/SI7021
                                          tttadam @robert-hh
                                          @robert-hh Awsome! Thank you
                                          • 1
                                          • 2
                                          • 3
                                          • 3 / 3
