AS923 Class C not working?
I ran into a problem trying to use class C on AS923.
Class A works like expected, but when I change to class C, I cannot receive anything. The joining procedure works fine.
This is my declaration:
global lora lora = LoRa(mode=LoRa.LORAWAN, power_mode=LoRa.ALWAYS_ON, region=LoRa.AS923, device_class=LoRa.CLASS_C)socket and Hello message:
pycom.rgbled(0x141400) # create a LoRa socket global lsock lsock = socket.socket(socket.AF_LORA, socket.SOCK_RAW) lsock.setsockopt( socket.SOL_LORA, socket.SO_DR, 2 ) # datarate lsock.setblocking(False) #send Hello packet print('sending Hello') lsock.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, 1 ) model = 0 if 'model' in settings.dic: model = settings.dic['model'] send( bytes([ CMD_HI , 3, settings.PROTO_VERSION, settings.SW_VERSION, model ]) )This is how I wait for a message:
lsock.settimeout(10) lsock.setsockopt( socket.SOL_LORA, socket.SO_CONFIRMED, 0 ) print('waiting for data') while(True): try: data, port = lsock.recvfrom(128) proto_handler_multi(data, port) except TimeoutError: send(bytes([0x01,0x00])) #print('still waiting...') continueThe gateway (a CloudGate) receives the message and sends messages when I want to but I don't see anything happening on the LoPy. Anyone ran into this issue before?
What lorawan server are you using ? You can see downlink packets on your lora gateway ?
I am Using a CloudGate and create the packets on the gateway itself. I can see the packets being sent, but nothing received on the LoPy. When I changed to EU HW and changed my code to EU868, it worked normally.
When I send from the LoPy to the gateway, I also see the packets of my LoPy.
Also Class A functions normally. It looks like it's not listening in Class C when using AS923. How can I confirm this? -
@harald You may want to check the region-related files in the source code to see if there's anything obvisouly different on the topic for AS923.
I have to admit I don't even know how channel/data rate selection works for class C downlinks... I suppose there must be default channels, and some MAC commands to change that?
What type of join are you using? OTAA or ABP?
@jcaron said in AS923 Class C not working?:
Channel plan is the same for Class A and Class C devices, difference is how downlink delivered. Class A devices listen continously on RX2 channel after RX1 window closed followed by uplink, so you can send downlink any time. Class C is also used for Multicast but as far as I know it is not implemented by PyCom.
@jcaron
I'm using OTAA and can see the joining works like it should. -
@harald. Please can you send your complete code to support (support@pycom.io) ? Class C in the AS923 region works. Please see the pic below:
The files have been sent! Thanks for looking into this! I will update this thread once the code is fully functional.
Can you tell what is wrong with this code then:
from network import LoRa import socket import binascii import settings import sys import time import pycom LORA_FREQUENCY = 923000000 LORA_FREQ_ADD = 20000 LORA_GW_DR = "SF10BW125" LORA_NODE_DR = 2 # initialize LoRa in LORAWAN mode. # Please pick the region that matches where you are using the device: # Asia = LoRa.AS923 # Australia = LoRa.AU915 # Europe = LoRa.EU868 # United States = LoRa.US915 lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AS923, device_class=LoRa.CLASS_C) # create an OTA authentication params dev_eui = binascii.unhexlify('70b3d5499da97f9c') app_eui = binascii.unhexlify('ADA4DAE3AC12676B') app_key = binascii.unhexlify('11B0282A189B75B0B4D2D8C7FA38548B') # set the 3 default channels to the same frequency (must be before sending the OTAA join request) print('Adding channels') lora.add_channel(0, frequency=923200000, dr_min=0, dr_max=5) #join a network using OTAA print('Joining...') lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=LORA_NODE_DR) #lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0) # wait until the module has joined the network while not lora.has_joined(): time.sleep(2.5) print('Not joined yet...') print('Joined') # remove all the non-default channels print('Removing other channels') for i in range(1, 16): lora.remove_channel(i) # create a LoRa socket s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, LORA_NODE_DR) #test set unconfirmed. s.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, 0) # make the socket blocking s.setblocking(False) time.sleep(5.0) pkt = b'PKT #' + bytes([i]) print('Sending:', pkt) s.send(pkt) time.sleep(4) print('Listening...') while True: rx, port = s.recvfrom(256) if rx: print('Received: {}, on port: {}'.format(rx, port)) time.sleep(1)
