    Onewire library function does not work
    onewireds18b20sensor
    2 Posts 2 Posters 570 Views 2 Watching
    • B Offline
      brossingo
      Hi everyone! I am trying to read temperature values using a DS18x20 sensor and a 1-Wire. Thus I use both libraries which you can find here : https://github.com/pycom/pycom-libraries/blob/master/examples/DS18X20/onewire.py. However, the read_temp_async function keeps returning None as a result. Following the indication on the link, it says that this is due to the fact that the convertion is not completed but still, I do not understand why this is happening. I do not know if this is due to the code (which you can find down there and is very simple) or to the electronic circuit I made (which includes a Pycom device connected to the computer through a USB cable and this device is also connected to a breadboard containing the sensor). Thanks for helping
      ow=OneWire(Pin('G5'))
      r=DS18x20(ow)
      print(r.read_temp_async())
        robert-hh @brossingo
        @brossingo G5 is an input only pin, like G4, G0, G3, G31 and G30. Try another pin, like G22 or G17 or G7 or G6 or ....
