[solved] building in MINGW32 / make TARGET=app fails with 'no rule to make target'
Submitted issue @ https://github.com/pycom/pycom-micropython-sigfox/issues/220
Hello. I am trying to build firmware from source and make TARGET=app does not compile with following error. Hopefully it's something silly due to my unfamiliarity with the environment.
... CC ../py/../extmod/uos_dupterm.c CC ../py/../lib/embed/abort_.c CC ../py/../lib/utils/printf.c make: *** No rule to make target 'build/WIPY/release/frozen_mpy/frozen/Base/_boot.mpy', needed by 'build/WIPY/release/frozen_mpy.c'. Stop.
I have followed these instructions to setup the build environment on Windows 10:
- https://docs.espressif.com/projects/esp-idf/en/latest/get-started/
I am able to build vanilla esp-idf hello_world example. - https://github.com/pycom/pycom-micropython-sigfox
I did not download the listed xtensa gcc compiler since one already exists from step #1.
xtensa-esp32-elf-gcc.exe (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 5.2.0
$ printenv PATH /mingw32/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/opt/xtensa-esp32-elf/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
$ printenv IDF_PATH D:/msys32/home/chris/esp/pycom-esp-idf
- build
cd mpy-cross && make clean && make && cd .. cd esp32 make clean make TARGET=boot make TARGET=app make flash
output of mpy-cross:
LINK mpy-cross text data bss dec hex filename 128257 2596 708 131561 201e9 mpy-cross
output of boot target:
LINK xtensa-esp32-elf-gcc *** -nostdlib -Wl,-Map=build/WIPY/release/bootloader/bootloader.map -Wl,--no-check-sections -u call_user_start_cpu0 -Wl,-static -Wl,--undefined=uxTopUsedPriority -Wl,--gc-sections -T esp32.bootloader.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.bootloader.rom.ld -T esp32.rom.spiram_incompatible_fns.ld *** -Wl,--start-group -Lbootloader/lib -Lbootloader -Lbuild/WIPY/release/bootloader -LD:/msys32/home/chris/esp/pycom-esp-idf/components/esp32/ld -LD:/msys32/home/chris/esp/pycom-esp-idf/components/esp32/lib -llog -lcore -lbootloader_support -lspi_flash -lsoc -lmicro-ecc -lgcc -lstdc++ -lgcov build/WIPY/release/bootloader/bootloader.a -Wl,--end-group -Wl,-EL -o build/WIPY/release/bootloader/bootloader.elf text data bss dec hex filename 16310 8 40 16358 3fe6 build/WIPY/release/bootloader/bootloader.elf IMAGE build/WIPY/release/bootloader/bootloader.bin
Chris
Resolved...
diff --git a/py/mkrules.mk b/py/mkrules.mk index 633b0df..b9b235c 100644 --- a/py/mkrules.mk +++ b/py/mkrules.mk @@ -115,6 +115,13 @@ FROZEN_MPY_PY_FILES += $(shell find -L $(FROZEN_MPY_DIR)/Common/ -type f -name ' ifeq ($(BOARD), $(filter $(BOARD), GPY FIPY)) FROZEN_MPY_PY_FILES += $(shell find -L $(FROZEN_MPY_DIR)/LTE/ -type f -name '*.py' | $(SED) -e 's/$(FROZEN_MPY_DIR)\/LTE\///') endif +else ifeq ($(findstring MINGW32,$(OS_NAME)),MINGW32) +# make a list of all the .py files that need compiling and freezing +FROZEN_MPY_PY_FILES := $(shell find -L $(FROZEN_MPY_DIR)/Base/ -type f -name '*.py' | $(SED) -e 's/$(FROZEN_MPY_DIR)\/Base\///') +FROZEN_MPY_PY_FILES += $(shell find -L $(FROZEN_MPY_DIR)/Common/ -type f -name '*.py' | $(SED) -e 's/$(FROZEN_MPY_DIR)\/Common\///') +ifeq ($(BOARD), $(filter $(BOARD), GPY FIPY)) +FROZEN_MPY_PY_FILES += $(shell find -L $(FROZEN_MPY_DIR)/LTE/ -type f -name '*.py' | $(SED) -e 's/$(FROZEN_MPY_DIR)\/LTE\///') +endif else # make a list of all the .py files that need compiling and freezing FROZEN_MPY_PY_FILES := $(shell find -L $(FROZEN_MPY_DIR)/Base/ -type f -name '*.py' | $(SED) -e 's=^$(FROZEN_MPY_DIR)\/Base\//==')
