Fipy : LORA not responding
I am new to pycom and python please help. I tried making FIPY as gateway using below code
import struct import socket from network import LoRa import time import gc LORA_MSG_FORMAT = "LLBBBBlB" class incoming_message: def __init__(self, data): self.control, self.deviceID, self.Seq, self.indicator1, self.indicator2, self.stype, self.svalue, self.check = struct.unpack(LORA_MSG_FORMAT, data) #self.control is something added from RFM95. Just discard it. Your message starts from the 5th byte class server: def __init__(self): cfg_mode = LoRa.LORA cfg_freq = 868000000 cfg_bandwidth=LoRa.BW_125KHZ # LoRa.BW_125KHZ or LoRa.BW_250KHZ cfg_sf = 7 # Accepts values between 6 and 12. # 6 = 64 Chips/Symbol # 7 = 128 Chips/Symbol # 8 = 256 Chips/Symbol # 9 = 512 Chips/Symbol # 10 = 1024 Chips/Symbol # 11 = 2048 Chips/Symbol # 12 = 4096 Chips/Symbol cfg_preamble=8 #configures the number of pre-amble symbols. The default value is 8 cfg_coding_rate=LoRa.CODING_4_5 #LoRa.CODING_4_5, LoRa.CODING_4_6, LoRa.CODING_4_7 or LoRa.CODING_4_8 cfg_power_mode=LoRa.ALWAYS_ON #LoRa.ALWAYS_ON, LoRa.TX_ONLY or LoRa.SLEEP self.lora = LoRa(mode=cfg_mode, frequency=cfg_freq, bandwidth=cfg_bandwidth, sf=cfg_sf, preamble=cfg_preamble, coding_rate=cfg_coding_rate, rx_iq=True, power_mode=cfg_power_mode) self.lora.init(mode=LoRa.LORA, frequency=868000000, tx_power=14, bandwidth=LoRa.BW_125KHZ, sf=7, preamble=8, coding_rate=LoRa.CODING_4_5, power_mode=LoRa.ALWAYS_ON, tx_iq=False, rx_iq=False) self.lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW) self.lora_sock.setblocking(False) def update(self): raw_data = self.lora_sock.recv(61) if raw_data: try: msg = incoming_message(raw_data) if msg.deviceID % msg.Seq == msg.check: print("msg received. devid:", msg.deviceID, " seq:", msg.Seq) else: print("msg check failed") except: print("msg failed to parse") else: pass def test_server(): srv = server() while True: srv.update() test_server()
But atom after uploading loraTest.py , boot.py and main.py No response on terminal of atom
@sumanjha090 I assume you have some nodes around which send messages in the corresponding settings. Besides that, I would add a short sleep into the test_server() loop.
@sumanjha090 Hi, what are you trying to achieve? You only have print statements when receiving, otherwise this won't print anything.
