    BLE ATT Wrapper
    blebluetooth
    1 Posts 1 Posters 630 Views 2 Watching
      cmisztur
      Example of creating BLE GATT services and characteristics.
      https://github.com/cmisztur/pycom-ble-gatt-wrapper
      usage:
      import gc
      import utime
      import ubinascii
      import uos
      from machine import Timer
      from L99_BLEGATTS import BLEGATTS
      hardware_serial = ubinascii.hexlify(machine.unique_id()).decode()
      l99_serial = 'L99-%s' % hardware_serial
      def ble_connection_callback(is_connected):
          if is_connected:
              print("BLE connected")
              print("BLE disconnected")
      ble = BLEGATTS()
      ble.init(advert_name=l99_serial, connect_callback=ble_connection_callback)
      ble.addService(service_name='device_info',uuid=6154) \
          .addReadChar (name='l99_serial', uuid=0, static_read=l99_serial) \
          .addReadChar (name='hardware_serial', uuid=1, static_read=hardware_serial) \
          .addReadChar (name='sysname', uuid=2, dynamic_read=lambda cn,id: uos.uname()[0]) \
          .addReadChar (name='nodename', uuid=3, dynamic_read=lambda cn,id: uos.uname()[1]) \
          .addReadChar (name='release', uuid=4, dynamic_read=lambda cn,id: uos.uname()[2]) \
          .addReadChar (name='version_number', uuid=5, dynamic_read=lambda cn,id: uos.uname()[3].split(' on ')[0]) \
          .addReadChar (name='version_date', uuid=6, dynamic_read=lambda cn,id: uos.uname()[3].split(' on ')[1]) \
          .addReadChar (name='machine', uuid=7, dynamic_read=lambda cn,id: uos.uname()[4]) \
          .addReadChar (name='lora_version', uuid=8, dynamic_read=lambda cn,id: uos.uname()[5]) \
          .start()
      ble.addService(service_name='char_tests',uuid=0) \
          .addNotifyChar (name='note1', uuid=0, static_read=0) \
          .addReadNotifyChar (name='note2', uuid=1, static_read=0) \
          .addReadChar (name='self', uuid=2, dynamic_read=lambda cn,id: cn+str(id)) \
          .addReadWriteChar (name='r+w', uuid=3,
                              dynamic_read=lambda cn,id: char_rw_test_read(cn,id),
                              dynamic_write=lambda cn,id,val: char_rw_test_write(cn,id,val)) \
          .addReadWriteNotifyChar (name='r+w+n', uuid=4,
                                  dynamic_read=lambda cn,id: char_rwn_test_read(cn,id),
                                  dynamic_write=lambda cn,id,val: char_rwn_test_write(cn,id,val)) \
          .start()
      ble.advertise()
      rw_var = 1337
      def char_rw_test_read(char_name,char_uuid):
          global rw_var
          return rw_var
      def char_rw_test_write(char_name,char_uuid,char_value):
          global rw_var
          rw_var = char_value
      def char_rwn_test_read(char_name,char_uuid):
          global rw_var
          return rw_var
      def char_rwn_test_write(char_name,char_uuid,char_value):
          global rw_var
          rw_var = char_value
          global ble
          ble.setCharValue('char_tests','r+w+n',rw_var) # ain't gonna notify itself
      def char_timer(t):
          global counter
          counter = counter + 1
          ble.setCharValue('char_tests','note1',counter)
          ble.setCharValue('char_tests','note2',counter) # i can only get one or the other to notify, but not both
      counter = 1
      timer = Timer.Alarm(handler=char_timer, ms=2000, periodic=True)
