    VSCode connection timed out
    vscodelopy4pytrack
    8 Posts 5 Posters 945 Views 5 Watching
      dfcarpenter
      I just got a new LoPy4 mounted on a PyTrack and cannot connect to the board at all through VSCode. I am using a Mac with USB-C ports and have a usb hub which the lopy4 is plugged into. The blue heartbeat is working and I can use the osx screen utility to connect to the board and run a few commands.
      In VScode when I run List Serial Ports I get
      /dev/tty.usbmodemPyb3c080 (Pycom) (copied to clipboard)
      I have switched between both
      /dev/cu.usbmodemPyb3c080 (which I see in /dev/)
      and on running Pymakr > Connect I just keep getting "Connection timed out. Click here to try again."
      I have tried pressing reset on the LoPy and nothing seems to work.
      Pymakr.json
      	"address": "/dev/cu.usbmodemPyb3c080",
      	"username": "micro",
      	"password": "python",
      	"sync_folder": "",
      	"open_on_start": true,
      	"safe_boot_on_upload": false,
      	"sync_file_types": "py,txt,log,json,xml,html,js,css,mpy",
      	"ctrl_c_on_connect": false,
      	"sync_all_file_types": false,
      	"auto_connect": false
      danD 1 Reply Last reply Reply Quote 0
        tttadam
        • danD Offline
          dan @dfcarpenter
          @dfcarpenter have you tried restarting your Mac? Sometimes I had issues with serial ports and that usually solved it. /dev/tty.usbmodemPyb3c080 should be the correct one.
          D 2 Replies Last reply Reply Quote 0
            dfcarpenter
              dfcarpenter @dan
              @dan
              Still getting connection errors
              Found 4 serialports
              /dev/tty.MALS (Unknown manufacturer)
              /dev/tty.SOC (Unknown manufacturer)
              /dev/tty.TaoTronicsTT-BH07-CSRGA (Unknown manufacturer)
              Connecting on /dev/tty.usbmodemPyb3c080...
                dfcarpenter @dan
                @dan
                Also for the screen utility on OSX I noticed I can only connect using
                /dev/cu.usbmodel* 115200
                not
                /dev/tty.usbmodel* 115200
                Which is strange to me because the List Serial Ports command from the plugin show me the *tty.
                • V Offline
                  voneone
                  Facing the extract same problem in VSCode (connection timed out). Do you have a solution?
                    This is a new issue (please do not reopen old threads), only on VSCode, we are working on a solution. There's another thread here on the recent issues: https://forum.pycom.io/topic/6809/pymakr-1-1-8-vs-code-failed-to-connect/ In the meantime, you can use Atom + Pymakr. Sorry for the inconvenience
