    Seeking advice on capturing time-stamped data
    wipy
    4 Posts 3 Posters 603 Views 3 Watching
    • R Offline
      robmarkcole
      Hi all
      I wish to record readings at 1 second intervals to the SD card using wipy/expansion board. For the time stamp I can use rtc.now() but there is no way to set the rtc.init() to be the true time, therefore if the board resets, I will have duplicate time-stamps. How do people recommend I deal with this?
      robert-hhR E 2 Replies Last reply Reply Quote 0
        robert-hh @robmarkcole
        @robmarkcole If you have Internet access, you can use rtc.ntp_sync(). Anyhow you should re-sync the RTC often, since it normally is driven by the internal RC oscillator, which is not too precise. You could also add an external RTC, or use the GPS clock of pytrack, if available..
        • R Offline
          robmarkcole
          Thanks @robert-hh
          • E Offline
            Elizar @robmarkcole
            @robmarkcole After reset, just pickup the last time stamp from the SD cards' data file. That wouldn't give you a precise time but no problems with duplicates.
