    ULP co-processor
    ulpcoprocessor
    2 Posts 2 Posters 467 Views 2 Watching
      david.tu
      Just want to know some more info and capabilities of this co-processor.
      Can the processor write to SD card during deep sleep mode.
      • nespressifN Offline
        nespressif
        Hello, here you have the link to the Espressif documentation (manufacturer of ESP32), but as far as I know Pycom firmware doesn't support ULP, so it can't be used.
        ULP (Ultra Low Power) coprocessor is a simple FSM which is designed to perform measurements using ADC, temperature sensor, and external I2C sensors, while main processors are in deep sleep mode. ULP coprocessor can access RTC_SLOW_MEM memory region, and registers in RTC_CNTL, RTC_IO, and SARADC peripherals. ULP coprocessor uses fixed-width 32-bit instructions, 32-bit memory addressing, and has 4 general purpose 16-bit registers.
