    Fipy + Pytrack v1.18.1.r4 + SNQNS Firmware CATM1-39592 - Verizon Socket Connection OSERROR:-1
    fipyverizonlte-msocket connect
    7 Posts 2 Posters 970 Views 3 Watching
    • W Offline
      wghirakawa
      Been trying this for several days, even reset SQNS Modem back to factory settings using at command to make sure that there are no issues. I am able to get ipaddress using the socket.getaddrinfo() function but, as far as connecting to the socket using the return addrinfo, i get an OSERROR:-1. Below is the code I am attempting to execute.
      import ssl
      from network import LTE
      print('creating LTE object - carrier verizon')
      # lte = LTE()
      lte = LTE(carrier="verizon")
      # lte = LTE(carrier="at&t")         # instantiate the LTE object
      print('resetting modem, may take up to 5 secs...')
      lte.reset()
      print('attaching...')
      lte.attach()        # attach the cellular modem to a base station
      # lte.attach(band=13)        # attach the cellular modem to a base station
      while not lte.isattached():
          print('waiting for isattached...')
          time.sleep_ms(1000)
      print('connecting...')
      # lte.connect()       # start a data session and obtain an IP address
      lte.connect(cid=3)    # cid=3 for verizon - start a data session and obtain an IP address
      while not lte.isconnected():
          print('waiting for isconnected...')
          time.sleep_ms(500)
      print('create socket')
      s = socket.socket()
      print("Connect to: www.ces-web.com")
      sockaddr = socket.getaddrinfo('www.google.com', 80)[0][-1]
      #print("Connect to: www.google.com")
      #s = ssl.wrap_socket(s)
      #sockaddr = socket.getaddrinfo('www.google.com', 443)[0][-1]
      print("socket address: {}".format(sockaddr))
      s.connect(sockaddr)
      print("send GET request")
      s.send(b"GET / HTTP/1.0\r\n\r\n")
      print("receive response")
      print(s.recv(16))
      s.close()
      print("socket closed")
      lte.disconnect()
      print("disconnected")
      lte.dettach()
      print("dettached")
      lte.deinit()
      print("deinit")
      The response I get when executing s.connect() is as follows.
        File "<stdin>", line 38, in <module>
      OSError: -1
      Need help please! @Xykon & @rskoniec
      If everyone in the world could do their passion, the world would be an unbelievable place!
        danielm
        Try it with 1.18.1.r6.
        W 1 Reply Last reply Reply Quote 0
        • W Offline
          wghirakawa
          Will try with r6. Thanks @danielm
          • W Offline
            wghirakawa @danielm
            @danielm where can I find r6. I tried doing the development version via the pycom firmware updater and it only download b5.
              danielm @wghirakawa
              @wghirakawa
              It is a pre-release which is available for download here:
              https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.18.1.r6
              • W Offline
                wghirakawa @danielm
                @danielm r6 pre-release Did not work either. Please see code and output below.
                import ssl
                # lte = LTE()
                    time.sleep_ms(1000)
                    time.sleep_ms(500)
                s = socket.socket()
                s.connect(sockaddr)
                print(s.recv(16))
                s.close()
                lte.disconnect()
                lte.dettach()
                print("dettached")
                lte.deinit()
                print("deinit")
                >>> import os
                >>> os.uname
                <function>
                >>> os.uname()
                (sysname='FiPy', nodename='FiPy', release='1.18.1.r6', version='v1.8.6-849-a8966d1 on 2018-11-23', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1')
                >>> Running test.py
                attaching...
                connecting...
                create socket
                socket address: ('172.217.164.100', 80)
                  File "<stdin>", line 39, in <module>
                OSError: -1
                Pycom MicroPython 1.18.1.r6 [v1.8.6-849-a8966d1] on 2018-11-23; FiPy with ESP32
                >>> import sqnsupgrade
                >>> sqnsupgrade.
                reconnect_uart  crc             LTE             __name__
                VERSION         UART            uart            detect_error
                info            sqnsupgrade     struct          time
                SD              sys             os              sysname
                run             print_welcome   release         stp
                >>> sqnsupgrade.VERSION
                '1.2.0'
                >>> sqnsupgrade.info()
                <<< Welcome to the SQN3330 firmware updater [1.2.0] >>>
                >>> FiPy with firmware version 1.18.1.r6
                UE5.0.0.0d
                LR5.1.1.0-39529```
                  danielm @wghirakawa
                  @wghirakawa
                  The code seems to be ok. I don't have access to Cat M1 network (only NB-IoT available here) so I cannot test with the same Sequans firmware.
                  Are you able to perform communication on the same APN and with the same SIM using different hardware?
                  @iwahdan could you please take a look?
