    NB-IoT in Hungary?
    Scheduled Pinned Locked Moved Cellular
    nbiottsystemsvodafone
    18 Posts 4 Posters 2.4k Views 5 Watching
    • bmarkusB Offline
      bmarkus
      Has anybody experience with NB-IoT modules in Hungary? Primarily Telecom (T-Systems) but Vodeafone is also interesting.
        Paul Thornton
        What was it you wanted to know, I dont have any direct experience (Im over in the UK) but would happily help you find out the info you require :)
          combaindeft @Paul Thornton
          @paul-thornton Hi,
          Related to a different Country ... Sweden ... I'm having issues in getting NB-IOT to work via Telia NB-IOT :-(
          Here is a log of the output:
          Initializing filesystem as FatFS!
          DEBUG :: START-UP        :: @ 3 :: FREE MEM 2519792
          DEBUG :: ENABLE GC       :: @ 3 :: FREE MEM 2519536
          DEBUG :: IMPORT MACHINE  :: @ 5 :: FREE MEM 2519264
          DEBUG :: IMPORT BinASCII :: @ 6 :: FREE MEM 2519008
          DEBUG :: IMPORT PyCom    :: @ 6 :: FREE MEM 2518736
          DEBUG :: IMPORT SOCKET   :: @ 6 :: FREE MEM 2518480
          DEBUG :: IMPORT USOCKET   :: @ 6 :: FREE MEM 2518160
          DEBUG :: IMPORT LoRa     :: @ 6 :: FREE MEM 2517888
          DEBUG :: IMPORT NETWORK  :: @ 6 :: FREE MEM 2517632
          DEBUG :: IMPORT Acceloramoter :: @ 7 :: FREE MEM 2512784
          DEBUG :: IMPORT L76GNSS  :: @ 7 :: FREE MEM 2509328
          DEBUG :: IMPORT PyTrack  :: @ 8 :: FREE MEM 2505232
          DEBUG :: IMPORT UbinASCII :: @ 8 :: FREE MEM 2507680
          DEBUG :: IMPORT Wia.IO urequests :: @ 9 :: FREE MEM 2501104
          DEBUG :: IMPORT Sigfox :: @ 9 :: FREE MEM 2501904
          DEBUG :: IMPORT Struct :: @ 9 :: FREE MEM 2501936
          DEBUG :: IMPORT SD :: @ 9 :: FREE MEM 2501920
          DEBUG :: IMPORT LTE :: @ 10 :: FREE MEM 2501888
          DEBUG :: IMPORT SYS :: @ 10 :: FREE MEM 2501904
          DEBUG :: IMPORT RTC :: @ 10 :: FREE MEM 2501888
          @ L76GNSS :: __init__ :: PyTrack I2C
          LOG: Define global lat, lng
          LOG: Define global DEBUG_LAT, DEBUG_LNG
          LOG: Set global DEBUG_LAT, DEBUG_LNG to DeGaVi: 55.7068,13.1893
          LOG: Define WIFI's
          LOG: Define global wlan
          LOG: Mount SD() to /sd
          LOG: listdir of /sd
          LOG: Initializing LTE NB-IOT
          LOG: define LTE()
          LOG: Reset LTE()
          LOG: Disonnecting LTE ... OK
          LOG: Detaching LTE ... OK
          LOG: LTE IMEI: 354346099263716
          LOG: AT CMD: AT+CFUN=0
          OK
          LOG: AT CMD: AT!="clearscanconfig"
          OK
          LOG: AT CMD: AT!="addscanfreq band=20 dl-earfcn=6252"
          OK
          LOG: AT CMD: AT+CGDCONT=1,"IP","lpwa.telia.iot"
          OK
          LOG: AT CMD: AT+CEREG=2
          OK
          LOG: AT CMD: AT+CFUN=1
          OK
          LOG: AT+COPS?
          +COPS: 1
          OK
          LOG: AT+COPS?
          +COPS: 1
          OK
          LOG: AT+COPS?
          +COPS: 1,2,"24001",9
          OK
          LOG: AT CMDs for Telia NB-IOT
          LOG: AT CMD: AT+CMEE=1
          OK
          LOG: AT CMD: AT+CGPADDR
          +CGPADDR: 1,"10.17.188.239"
          OK
          LOG: Attaching to LTE network  OK
          LOG: Check LTE signal streanght (RSSI): +CSQ: 24,99OK
          LOG: Getting IP address: +CGPADDR: 1,"10.17.188.239"OK
          +CGDATA: ("PPP")
          OK
          LOG: Connecting on LTE network  OK
          ('64.47.254.63', 80)
          ('1.0.0.0', 80)
          ('1.0.0.0', 80)
          ('1.0.0.0', 80)
          ('1.0.0.0', 80)
          ('1.0.0.0', 80)
          Pycom MicroPython 1.20.0.rc0 [v1.9.4-9f0896a] on 2018-12-08; FiPy with ESP32
          So as you can see, I'm connecting, getting an iP address ... but I cannot do a DNS resolve of some domain names :-(
          def lte_check_ip():
              # Delay between each event
              DELAY = 5
              print(usocket.getaddrinfo("api.wia.io", 80)[0][-1])
              time.sleep(DELAY)
              time.sleep(DELAY)
              time.sleep(DELAY)
              print(usocket.getaddrinfo("www.google.se", 80)[0][-1])
              time.sleep(DELAY)
              time.sleep(DELAY)
          As you also can check, the IP address for api.wia.io isn't: 64.47.254.63
          [temp @ isx-deft : ~ ]  $ ping api.wia.io
          PING api.wia.io (52.17.209.228): 56 data bytes
          64 bytes from 52.17.209.228: icmp_seq=0 ttl=41 time=53.890 ms
          64 bytes from 52.17.209.228: icmp_seq=1 ttl=41 time=44.260 ms
          64 bytes from 52.17.209.228: icmp_seq=2 ttl=41 time=45.222 ms
          64 bytes from 52.17.209.228: icmp_seq=3 ttl=41 time=60.190 ms
          64 bytes from 52.17.209.228: icmp_seq=4 ttl=41 time=46.505 ms
          64 bytes from 52.17.209.228: icmp_seq=5 ttl=41 time=45.736 ms
          64 bytes from 52.17.209.228: icmp_seq=6 ttl=41 time=44.705 ms
          ^C
          --- api.wia.io ping statistics ---
          7 packets transmitted, 7 packets received, 0.0% packet loss
          round-trip min/avg/max/stddev = 44.260/48.644/60.190/5.610 ms
            Paul Thornton @combaindeft
            @combaindeft
            HI, Thanks for that. Let me see what I can find out and get back to you.
            I know we had some issues around dns resolution recently that have recently been fixed in the latest RC firmware. https://forum.pycom.io/topic/4099/new-firmware-release-candidate-v1-20-0-rc0/ Im not certain if this is one of them but it would be worth giving that a try if you havent already.
              @paul-thornton Yeah, I know about that, I was one of them that has already logged that issue :-)
              As for the The output you saw, is from running the latest development build
              And this time around both api.wia.io and www.google.se is giving the same result.
              LOG: Attaching to LTE network ... OK
              LOG: Check LTE signal streanght (RSSI): +CSQ: 25,99OK
              LOG: Getting IP address: +CGPADDR: 1,"10.17.191.218"OK
              +CGDATA: ("PPP")
              OK
              LOG: Initializing DNS query of domain name(s)
              LOG: api.wai.io
              ('184.109.15.128', 80)
              LOG: api.wai.io
              LOG: api.wai.io
              LOG: www.google.se
              LOG: www.google.se
              LOG: www.google.se
                danielm @combaindeft
                @combaindeft
                Are you getting DNS server IP address from the network? You can check with 'AT+CGCONTRDP' command.
                From Sequans AT command manual:
                The execution command returns the relevant information <bearer_id>,
                <apn>, <local_addr and subnet_mask>, <gw_addr>,
                <DNS_prim_addr>, <DNS_sec_addr>, <P-CSCF_prim_addr>,
                <P-CSCF_sec_addr>, <IM_CN_Signalling_Flag> and
                <LIPA_indication> for an active non secondary PDP context with the
                context identifier <cid>.
                C 2 Replies Last reply Reply Quote 0
                  combaindeft @danielm
                  @danielm
                  Here is what I'm getting:
                  >>> send_at_cmd_pretty('AT+CGCONTRDP')
                  +CGCONTRDP: 1,5,"lpwa.telia.iot.mnc020.mcc238.gprs","10.17.160.100.255.255.255.255","","","","",""
                  OK
                    @danielm
                    Also, having e-mailed with them (Telia) a bit, I do know that the GSSN's ip-address is 217.214.135.1
                    Is there a way to set the DNS_prim_addr to it?
                      @combaindeft said in NB-IoT in Hungary?:
                      There is no such command in the AT command manual. There may be some undocumented command. I am testing in network of Slovak Telekom and DNS servers are not provided by the network here as well.
                      Another approach may be to write DNS lookup library.
                      C P 2 Replies Last reply Reply Quote 0
                      • bmarkusB Offline
                        bmarkus
                        Just wanted to know is it whorth to buy any NB-IoT capeble PyCom module for Hungary.ű
                        Guys, it is great you hijacked my topic, really said to see it. Why don't you open a new thread instead?
                          @danielm
                          Thanks for the great info ... but I don't think a DNS Lookup library is worth is ... since the NB-IOT network via Telia is UDP only ... ergo "one-way" communication ... so, a device is only allowed to send but never receive :-(
                          (and it does make sense, since IOT devices are ment to be low-power and not use a lot of broadband ...)
                            combaindeft @bmarkus
                            @bmarkus
                            Right now, everything is in development and it all depends how far they have come in Hungary ... maybe call all our Telecom Operators in Hungary and ask if they support NB-IOT?
                            If you are lucky, they'll say yes - they do ... and at the same moment starts your next headache ... will the help you in telling you how to get things working with their network?
                            And 3rd headache, does the board you buy support them ...
                            So far from all the testing, the PyCom FiPy is almost there ... in sweden at least ... I can attach to the network and connected (get an iP) ... but the remaining question now is how to send data over the connection ...
                            Right now ... attaching seems oK ... as we can continue playing with sending AT-commands to the modem ...
                            But when we "connect" ... and it goes into setting up a PPP-connection (ergo a "data"-link ... like on your phone when you browse the webz...) ... it doesn't work.
                            Here I suggest to PyCom to add a usocket.AF_NBIOT option in USocket ... as they've done with SIGFOX and LORA ... to forcefully direct the data through NB-IOT
                            s_nb = usocket.socket(usocket.AF_NBIOT, usocket.SOCK_DGRAM, usocket.IPPROTO_UDP)
                            (mainly as we we are testing with LoRa, Sigfox, WiFi and Bluetooth ... you'd like to tell the sockets what connection to use ... and not let the "socket" decide for you ...)
                            Anywho ... hope it helps you a bit.
                            And as for hijacking your topic ... sorry a-bout that ... but have already started a topic ... and old topics get berried quite quickly in this active forum :-)
                            bmarkusB 1 Reply Last reply Reply Quote 0
                              @combaindeft
                              UDP-only NB-IoT network is bidirectional as well. DNS protocol works over UDP :)
                                @danielm
                                From my testing so far, on the Network I'm on ... the UDP connection seems only to be one-direction :-)
                                But I'll stand corrected :-)
                                  Paul Thornton @danielm
                                  @danielm Just to clarify. Ive asked.There is no undocumented command to set a dns server if not already provided by the network operator. (At the moment)
                                    danielm @Paul Thornton
                                    @paul-thornton
                                    Hi Paul, thanks for clarification. I think it would be helpful if Pycom could implement DNS client which would work independently from NIC's API and which would accept DNS server IP address as an optional parameter.
                                    • bmarkusB Offline
                                      bmarkus @combaindeft
                                      @combaindeft Telekom announced publicly 60% national, 100% Budapest coverage. Question is not about coverage but PyCom usability. I can use e.g. QUECTEL without any problem.
                                        @bmarkus said in NB-IoT in Hungary?:
                                        Today I had a break-through and can send data via AT-Commands ...
                                        Though, to make a proper data-connection and use USocket to send data ... that it's up to PyCom to add support for handling their network (had a talk with Telia here in Sweden today regarding their NB-IOT network).
                                        So yeah, question is how fast PyCom can add support for all operators data Networks around the globe.
