    JSON posts
    requestsurequestsmicropython
    4 Posts 2 Posters 899 Views 2 Watching
    • K Offline
      kjm
      I use this code in python on a rpi to do JSON posts
      import requests
      payload = '{"msg_type":"observation_payload","msg":{"serial":"FZtank","observations":{"8":{"d":0,"m":"JSON upload test","t":"1543540780"}}}}'
      r = requests.post('https://my.website/api/observations', data = {'post_wrapper':payload})
      print r.text
      & it prints
      {"msg": {"remote_pi": "FZtank", "stored_ids": ["8"]}, "msg_type": "receipt"}
      I figured it wouldn't be too hard to do the same thing in micropython on pycom device
      import urequests as requests
      r = requests.post('https://my.website/api/observations', data = {"post_wrapper":payload})
      print(r.text)
      r.close()
      but it gives
        File "<stdin>", line 12, in <module>
        File "/flash/lib/urequests.py", line 115, in post
        File "/flash/lib/urequests.py", line 100, in request
        File "/flash/lib/urequests.py", line 79, in request
      TypeError: object with buffer protocol required
      The TypeError msg means it wants a string instead of a dictionary for the data so I tried
      payload = '{"post_wrapper":{"msg_type":"observation_payload","msg":{"serial":"FZtank","observations":{"8":{"d":0,"m":"JSON upload test","t":"1543540780"}}}}}'
      r = requests.post('https://my.website/api/observations', data =payload)
      print(r.text)
      r.close()
      but that gives
      {"msg": {"errorText": "Malformed POST - unable to decode JSON"}, "msg_type": "error"}
      So now I'm confused. Is the problem that the website expects a dictionary & micropython can only send a string?
      • E Offline
        Eric73 @kjm
        @kjm Have you try something like this ?
        import ujson
        r = requests.post('https://my.website/api/observations', data = ujson.dumps({"post_wrapper":payload}))
        print(r.text)
        r.close()
        Micro python is a small python sub part, so it have smaller library than python but ujson must do the job you request. (where urequests come from it's not a pycom library isn't it ?)
        If it come from https://github.com/micropython/micropython-lib/blob/master/urequests/urequests.py
        then you can just do
        r = requests.post('https://my.website/api/observations', json = {"post_wrapper":payload})
        • K Offline
          kjm
          It doesn't like ujson.dumps either
            File "<stdin>", line 11, in <module>
            File "/flash/lib/urequests.py", line 52, in request
          OSError: 128
          int(port) in the library seems harmless enough?
          49   if ":" in host:
          50       host, port = host.split(":", 1)
          51       port = int(port)
          52    ai = usocket.getaddrinfo(host, port)
          53    #ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)
          I'm using the library you linked to (albeit with line 53 changed to stop it crashing) but it won't do json = {"post_wrapper":payload}) either, says TypeError: 'module' object is not callable
          • E Offline
            Eric73 @kjm
            @kjm Line 52 doesn't seem to be related to datapayload, so i suppose that data = ujson.dumps({"post_wrapper":payload})) do the work.
            I don't know what OSError 128 mean but the line seem to be related to networking. Does your software have do correctly the connect with your wifi hotspot before trying to send your request ?
